Sensitivity of dynamical seasonal forecasts to ocean initial conditions, Quarterly Journal of the Royal Meteorological Society, vol.131, issue.597, pp.647-668, 2004. ,
DOI : 10.1256/qj.03.25
1991 A study of the use of scatterometer data in the ECMWF Operational Analysis -Forecast model. Part II Data impact, J. Geophys. Res, vol.96, pp.2-2635 ,
Ocean data assimilation for seasonal forecasts. ECMWF Seminar Proceedings. Seminar on Recent developments in data assimilation for atmosphere and ocean, pp.301-326, 2003. ,
Balanced Ocean-Data Assimilation near the Equator, Journal of Physical Oceanography, vol.32, issue.9, pp.2509-2519, 2002. ,
DOI : 10.1175/1520-0485-32.9.2509
Impact of altimeter, thermistor, and expendable bathythermograph data on retrospective analyses of the tropical Pacific Ocean, Journal of Geophysical Research: Oceans, vol.95, issue.C6, pp.147-161, 1996. ,
DOI : 10.1029/96JC00631
Altimetric assimilation with water property conservation, Journal of Geophysical Research: Oceans, vol.5, issue.C1, pp.1059-1077, 1996. ,
DOI : 10.1029/95JC02902
Atmospheric data analysis, La M??t??orologie, vol.8, issue.9, p.457, 1991. ,
DOI : 10.4267/2042/51948
The Impact of Data Assimilation on ENSO Simulations and Predictions, Monthly Weather Review, vol.125, issue.5, pp.819-829, 1997. ,
DOI : 10.1175/1520-0493(1997)125<0819:TIODAO>2.0.CO;2
): Covariance Relationships, Monthly Weather Review, vol.134, issue.3, pp.759-771, 2006. ,
DOI : 10.1175/MWR3089.1
Quality control of ocean profiles -historical and real time data, Journal of Marine Sciences, 2006. ,
An improved coupled model for ENSO prediction and implications for ocean initialisation, 1998. ,
Use of TOPEX/Poseidon Sea Level Data for Ocean Analyses and ENSO Prediction: Some Early Results, Journal of Climate, vol.13, issue.1, pp.216-231, 2000. ,
DOI : 10.1175/1520-0442(2000)013<0216:UOTPSL>2.0.CO;2
Assimilation of Subsurface Thermal Data into a Simple Ocean Model for the Initialization of an Intermediate Tropical Coupled Ocean-Atmosphere Forecast Model, Monthly Weather Review, vol.123, issue.10, pp.3103-3113, 1995. ,
DOI : 10.1175/1520-0493(1995)123<3103:AOSTDI>2.0.CO;2
Using satellite-derived sea level and temperature profiles for determining the salinity variability: A new approach, Journal of Geophysical Research: Oceans, vol.16, issue.C4, pp.8537-8547, 2000. ,
DOI : 10.1029/1999JC900279
A global ocean temperature and altimeter data assimilation system for studies of climate variability, Climate Dynamics, vol.17, issue.9, pp.687-700, 2000. ,
DOI : 10.1007/s003820000142
The Tropical Atmosphere-Ocean Array is completed, Bull. Amer. Meteor. Soc, vol.76, pp.739-741, 1995. ,
A Gulf Stream model and an altimetry assimilation scheme, Journal of Geophysical Research, vol.95, issue.C5, pp.8779-8795, 1991. ,
DOI : 10.1029/91JC00383
Space and time scales for optimal interpolation of temperature ??? Tropical Pacific Ocean, Progress in Oceanography, vol.28, issue.3, pp.189-218, 1991. ,
DOI : 10.1016/0079-6611(91)90008-A
A High-Resolution Global Sea Surface Temperature Climatology, Journal of Climate, vol.8, issue.6, pp.571-1583, 1995. ,
DOI : 10.1175/1520-0442(1995)008<1571:AHRGSS>2.0.CO;2
An Improved In Situ and Satellite SST Analysis for Climate, Journal of Climate, vol.15, issue.13, pp.1609-1625, 2002. ,
DOI : 10.1175/1520-0442(2002)015<1609:AIISAS>2.0.CO;2
Incorporating State-Dependent Temperature???Salinity Constraints in the Background Error Covariance of Variational Ocean Data Assimilation, Monthly Weather Review, vol.133, issue.1, 2005. ,
DOI : 10.1175/MWR2872.1
URL : https://hal.archives-ouvertes.fr/hal-00124827
Anomalous temperature and salinity variations in the tropical Atlantic: Possible causes and implications for the use of altimeter data, Geophysical Research Letters, vol.21, issue.No.4, p.2281, 2000. ,
DOI : 10.1029/1999GL011310
Toward the Use of Altimetry for Operational Seasonal Forecasting, Journal of Climate, vol.13, issue.17, pp.3116-3138, 2000. ,
DOI : 10.1175/1520-0442(2000)013<3115:TTUOAF>2.0.CO;2
Initialization of Seasonal Forecasts Assimilating Sea Level and Temperature Observations, Journal of Climate, vol.14, issue.22, pp.4292-4307, 2001. ,
DOI : 10.1175/1520-0442(2001)014<4292:IOSFAS>2.0.CO;2
A Pilot Research Moored Array in the Tropical Atlantic, Bulletin of the, pp.10-2019, 1998. ,
