Line transversals to disjoint balls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We prove that the set of directions of lines intersecting three disjoint balls in $\mathbb{R}^3$ in a given order is a strictly convex subset of $\mathbb{S}^2$. We then generalize this result to $n$ disjoint balls in $\mathbb{R}^d$. As a consequence, we can improve upon several old and new results on line transversals to disjoint balls in arbitrary dimension, such as bounds on the number of connected components and Helly-type theorems.
Cone-socg07.pdf (454.59 Ko) Télécharger le fichier
inria-00176201 , version 1 (02-10-2007)
Ciprian Borcea, Xavier Goaoc, Sylvain Petitjean. Line transversals to disjoint balls. 23rd Annual ACM Symposium on Computational Geometry 2007 - SoCG'07, 2007, Gyeongju, South Korea. pp.245-254, ⟨10.1145/1247069.1247115⟩. ⟨inria-00176201⟩
125 Consultations
164 Téléchargements
