A case-based reasoning approach for invoice structure extraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Hatem Hamza
  • Fonction : Auteur
  • PersonId : 830528
Yolande Belaïd
Abdel Belaïd
  • Fonction : Auteur
This paper shows the use of case-based reasoning (CBR) for invoice structure extraction and analysis. This method, called CBR-DIA (CBR for Document Invoice Analysis), is adaptive and does not need any previous training. It analyses a document by retrieving and analysing similar documents or elements of documents (cases) stored in a database. The retrieval step is performed thanks to graph comparison techniques like graph probing and edit distance. The analysis step is done thanks to the information found in the nearest retrieved cases. Applied on 950 invoices, CBR-DIA reaches a recognition rate of 85.29% for documents of known classes and 76.33% for documents of unknown classes.
version_publiee_IEEE.pdf (348.01 Ko) Télécharger le fichier
inria-00176644 , version 1 (25-01-2008)
Hatem Hamza, Yolande Belaïd, Abdel Belaïd. A case-based reasoning approach for invoice structure extraction. 9th International Conference on Document Analysis and Recognition - ICDAR'07, IAPR, Sep 2007, Curitiba, Brazil. pp.327--331, ⟨10.1109/ICDAR.2007.4378726⟩. ⟨inria-00176644⟩
123 Consultations
1354 Téléchargements
