A Learning Algorithm for Boltzmann Machines*, Cognitive Science, vol.85, issue.1, pp.147-169, 1985. ,
DOI : 10.1207/s15516709cog0901_7
Spatiotemporal energy models for the perception of motion, Journal of the Optical Society of America A, vol.2, issue.2, pp.284-299, 1985. ,
DOI : 10.1364/JOSAA.2.000284
The Handbook of Brain Theory and Neural Networks, 1995. ,
Generative Model of Curve Images with a Completely- Characterized Non-Gaussian Joint Distribution, Workshop on Statistical and Computational Theories of Vision at ICCV, 2001. ,
Theory of orientation tuning in visual cortex., Proc. Nat.l Academy of Sciences of USA, p.92, 1995. ,
DOI : 10.1073/pnas.92.9.3844
The Improved Iterative Scaling Algorithm: A Gentle Introduction, 1997. ,
Robust anisotropic diffusion, IEEE Transactions on Image Processing, vol.7, issue.3, pp.421-432, 1998. ,
DOI : 10.1109/83.661192
Visual Reconstruction, 1987. ,
A Computational Approach to Edge Detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.8, pp.679-698, 1986. ,
Summation and division by neurons in primate visual cortex, Science, vol.264, issue.5163, pp.264-1333, 1994. ,
DOI : 10.1126/science.8191289
Linearity and Normalization of Simple Cells of the Macaque Primary Visual Cortex, Journal of Neuroscience, vol.17, pp.8621-8644, 1997. ,
Absolute Stability of Global Pattern Formation and Parallel Memory Storage by Competitive Neural Networks, IEEE Transactions on Systems , Man, and Cybernetics, pp.13-815, 1983. ,
Uncertainty relation for resolution in space, spatial frequency, and orientation optimized by two-dimensional visual cortical filters, Journal of the Optical Society of America A, vol.2, issue.7, pp.160-169, 1985. ,
DOI : 10.1364/JOSAA.2.001160
Using Canny's criteria to derive a recursively implemented optimal edge detector, International Journal of Computer Vision, vol.1, issue.2, pp.167-187, 1987. ,
DOI : 10.1007/BF00123164
Contour integration by the human visual system: Evidence for a local ???association field???, Vision Research, vol.33, issue.2, pp.173-193, 1993. ,
DOI : 10.1016/0042-6989(93)90156-Q
Learning Low-Level Vision, Intl, International Journal of Computer Vision, vol.40, issue.1, pp.25-47, 2000. ,
DOI : 10.1023/A:1026501619075
The design and use of steerable filters, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.9, pp.891-906, 1991. ,
DOI : 10.1109/34.93808
Parallel and deterministic algorithms from MRFs: surface reconstruction, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.5, pp.401-412, 1991. ,
DOI : 10.1109/34.134040
Stochastic Relaxation, Gibbs Distributions, and the Bayesian Treatment of Images, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.66, pp.721-741, 1984. ,
The Temporal Correlation Hypothesis of Visual Feature Integration, Neuron, vol.24, issue.1, pp.24-31, 1999. ,
DOI : 10.1016/S0896-6273(00)80820-X
The Quantized Geometry of Visual Space: The Coherent Computation of Depth, Form and Lightness, The Behavioral and Brain Scinces, pp.625-657, 1983. ,
Cortical dynamics of three-dimensional surface perception: Binocular and half-occluded scenic images, Neural Networks, vol.10, issue.9, pp.1583-1605, 1997. ,
DOI : 10.1016/S0893-6080(97)00065-8
Neural dynamics of form perception: Boundary completion, illusory figures, and neon color spreading., Psychological Review, vol.92, issue.2, pp.173-211, 1985. ,
DOI : 10.1037/0033-295X.92.2.173
Neural dynamics of motion integration and segmentation within and across apertures, Vision Research, vol.41, issue.19, pp.2521-2553, 2001. ,
DOI : 10.1016/S0042-6989(01)00131-6
Synthetic aperture radar processing by a multiple scale neural system for boundary and surface representation, Neural Networks, vol.8, issue.7-8, pp.1005-1028, 1995. ,
DOI : 10.1016/0893-6080(95)00079-8
A laminar cortical model for 3D perception of slanted and curved surfaces and of 2D images: development, attention, and bistability, Vision Research, vol.44, issue.11, 2004. ,
DOI : 10.1016/j.visres.2003.12.009
Neural dynamics of 1-D and 2-D brightness perception: A unified model of classical and recent phenomena, Perception & Psychophysics, vol.15, issue.3, pp.43-241, 1988. ,
DOI : 10.3758/BF03207869
Inferring global pereeptual contours from local features, International Journal of Computer Vision, vol.4, issue.1, pp.113-133, 1996. ,
DOI : 10.1007/BF00144119
Inhibitory Interactions in the Retina of Limulus, in Physiology of Photoreceptor Organs, pp.381-447, 1972. ,
Optical flow using spatiotemporal filters, International Journal of Computer Vision, vol.300, issue.5892, pp.279-302, 1988. ,
DOI : 10.1007/BF00133568
Simulation of neural contour mechanisms: from simple to end-stopped cells, Vision Research, vol.32, issue.5, pp.963-981, 1992. ,
DOI : 10.1016/0042-6989(92)90039-L
A Computational Model Of Neural Contour Processing: Figure-Ground Segregation And Illusory Contours, Intl. Conf. on Computer Vision, pp.32-40, 1993. ,
Introduction to the Theory of Neural Computation, 1989. ,
Illusory contours and cortical neuron responses, Science, vol.224, issue.4654, pp.1260-1262, 1984. ,
DOI : 10.1126/science.6539501
Learning and Relearning in Boltzmann Machines, 1986. ,
A Quantitative Description of Ion Currents and its Applications to Conduction and Excitation in Nerve Membranes, Journal of Physiology, pp.500-544, 1952. ,
Shunting Inhibition Does Not Have a Divisive Effect on Firing Rates, Neural Computation, vol.298, issue.5, pp.1001-1013, 1997. ,
DOI : 10.1098/rspb.1978.0075
Neural Networks and Physical Systems with Emergent Collective Computational Abilities, Proc. Nat.l Academy of Sciences of USA, pp.2554-2558, 1982. ,
Neural Computation of Decisions in Optimization Problems, Biological Cybernetics, p.52, 1985. ,
The Curve of Least Energy, Tech. Rep. 612, MIT A.I. Lab, 1981. ,
Tutorial on Variational Approximation Methods, in Advanced Mean Field Methods: Theory and Practice, 2000. ,
Using Boltzmann Machines for probability estimation: A general framework for neural network learning, Intl. Conf. on Artificial Neural Networks, pp.521-526, 1993. ,
DOI : 10.1016/B978-0-444-81892-8.50031-6
Neural dynamics of 3-D surface perception: Figure-ground separation and lightness perception, Perception & Psychophysics, vol.26, issue.8, pp.1596-1619, 2000. ,
DOI : 10.3758/BF03212158
Biophysics of Computation: Information Processing in Single Neurons, 1999. ,
Analog "neuronal" networks in early vision., Proceedings of the National Academy of Sciences, vol.83, issue.12, 1985. ,
DOI : 10.1073/pnas.83.12.4263
A Biologically Motivated and Computationally Tractable Model of Low and Mid-Level Vision Tasks, European Conf. on Computer Vision, pp.506-517, 2004. ,
DOI : 10.1007/978-3-540-24671-8_40
Statistical edge detection: learning and evaluating edge cues, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.25, issue.1, p.25, 2003. ,
DOI : 10.1109/TPAMI.2003.1159946
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.116.2465
Invariant Measures of Image Features From Phase Information, 1996. ,
A Bayesian framework for understanding texture segmentation in the primary visual cortex, Vision Research, vol.35, issue.18, pp.2643-2657, 1995. ,
DOI : 10.1016/0042-6989(95)00032-U
Visual segmentation by contextual influences via intra-cortical interactions in the primary visual cortex, Network: Computation in Neural Systems, vol.10, issue.2, pp.187-212, 1999. ,
DOI : 10.1088/0954-898X_10_2_305
An Empirical Approach to Grouping and Segmentation, 2004. ,
Learning to detect natural image boundaries using local brightness, color, and texture cues, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.5, pp.530-549, 2004. ,
DOI : 10.1109/TPAMI.2004.1273918
A database of human segmented natural images and its application to evaluating segmentation algorithms and measuring ecological statistics, Proceedings Eighth IEEE International Conference on Computer Vision. ICCV 2001, pp.416-423, 2001. ,
DOI : 10.1109/ICCV.2001.937655
A neural network for enhancing boundaries and surfaces in synthetic aperture radar images, Neural Networks, vol.12, issue.3, pp.495-511, 1999. ,
DOI : 10.1016/S0893-6080(98)00144-0
Elastica and Computer Vision, in Algebraic Geometry and its applications, pp.507-518, 1993. ,
Optimal approximations by piecewise smooth functions and associated variational problems, Communications on Pure and Applied Mathematics, vol.3, issue.5, pp.577-685, 1989. ,
DOI : 10.1002/cpa.3160420503
Recurrent V1-V2 interaction in early visual boundary processing, Biological Cybernetics, vol.81, issue.5-6, pp.425-444, 1999. ,
DOI : 10.1007/s004220050573
Trace inference, curvature consistency, and curve detection, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.11, issue.8, pp.823-839, 1989. ,
DOI : 10.1109/34.31445
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.86.5694
Deformable Kernels for Early Vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.17, 1995. ,
DOI : 10.1109/cvpr.1991.139691
URL : http://authors.library.caltech.edu/30208/1/PERcvpr91.pdf
Detecting and localizing edges composed of steps, peaks and roofs, [1990] Proceedings Third International Conference on Computer Vision, pp.52-57, 1990. ,
DOI : 10.1109/ICCV.1990.139492
A Contrast- and Luminance-driven Multiscale Network Model of Brightness Perception, Vision Research, vol.35, issue.15, pp.2201-2223, 1995. ,
DOI : 10.1016/0042-6989(94)00313-0
Coupled Geometry Driven Diffusion Equations for Low-Level Vision, in Geometry Driven Diffusion in Computer Vision, 1994. ,
A Probabilistic Multi-scale Model for Contour Completion Based on Image Statistics, European Conf. on Computer Vision, pp.312-327, 2002. ,
DOI : 10.1007/3-540-47969-4_21
Visual cortical mechanisms of perceptual grouping: interacting layers, networks, columns, and maps, Neural Networks, vol.13, issue.6, pp.571-588, 2000. ,
DOI : 10.1016/S0893-6080(00)00040-X
Gain Modulation in the Central Nervous System: Where Behavior, Neurophysiology, and Computation Meet Neuroscientist, issue.7, pp.430-440, 2001. ,
Course Web-Page: Introduction to Neural Networks ,
Structural Saliency: the Detection of Globally Salient Structures Using a Locally Connected Network, Intl. Conf. on Computer Vision, pp.321-327, 1988. ,
A New Learning Algorithm for Mean Field Boltzmann Mahines, 2001. ,
Stochastic Completion Fields: A Neural Model of Illusory Contour Shape and Salience, Neural Computation, vol.6, issue.4, pp.837-858, 1997. ,
DOI : 10.1006/cviu.1996.0043
Computing Stochastic Completion Fields in Linear Time Using a Resolution Pyramid, Computer Vision and Image Understanding, pp.76-289, 1999. ,
Energy Functions for Early Vision and Ana- log Networks, The Handbook of Brain Theory and Neural Networks , M. Arbib, 1987. ,
A Common Framework for Image Segmentation, Intl, Journal of Computer Vision, vol.6, pp.227-243, 1991. ,
The Organization Of Curve Detection: Coarse Tangent Fields And Fine Spline Coverings, Intl. Conf. on Computer Vision route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex, pp.568-577, 1988. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rennes : IRISA, Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt, Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex ,
