Gestion de la réactivité des communications réseau - Archive ouverte HAL Access content directly
Reports (Research Report) Year : 2006
Communication mechanisms are most of the time implemented efficiently and therefore lead to good performances as long as the data transfer is done in an ``undisturbed environment'', i.e. the resources (CPU, memory bus, network interface) are fully available. On the other hand, communication reactivity during computing phases, i.e. the ability to react quickly to the network, is hard to ensure. However, by centralizing the network accesses, it is possible to maintain a good reactivity even during computing phases. In that context, we describe a new server, interacting with both a communication library and a thread scheduler, able to provide a good reactivity whatever the execution context is.
Tra06Memoire.pdf (139.1 Ko) Télécharger le fichier
Dates and versions
inria-00177149 , version 1 (05-10-2007)
Identifiers
  • HAL Id : inria-00177149 , version 1
Cite
François Trahay. Gestion de la réactivité des communications réseau. [Rapport de recherche] Universite Bordeaux 1. 2006, pp.31. ⟨inria-00177149⟩
120 View
91 Download
Share
