Galerkin finite element methods with symmetric pressure stabilization for the transient Stokes' equations: stability and convergence analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the stability and convergence analysis of pressure stabilized finite element approximations of the transient Stokes' equation. The analysis is valid for a class of symmetric pressure stabilization operators. Provided the initial data is chosen as a specific (pressure stabilization dependent) Ritz-projection, we get unconditional stability and optimal convergence for both pressure and velocity approximations, in natural norms. For arbitrary interpolations of the initial data, a condition between the space and time discretization parameters has to be verified in order guarantee pressure stability
burman-fernandez-07.pdf (452.41 Ko) Télécharger le fichier
inria-00178359 , version 1 (10-10-2007)
inria-00178359 , version 2 (11-10-2007)
inria-00178359 , version 3 (24-06-2008)
  • HAL Id : inria-00178359 , version 1
Erik Burman, Miguel Angel Fernández. Galerkin finite element methods with symmetric pressure stabilization for the transient Stokes' equations: stability and convergence analysis. [Research Report] 2007. ⟨inria-00178359v1⟩
508 Consultations
635 Téléchargements
