The book thickness of a graph, Journal of Combinatorial Theory, Series B, vol.27, issue.3, pp.320-331, 1979. ,
DOI : 10.1016/0095-8956(79)90021-2
On Triangulating Planar Graphs under the Four-Connectivity Constraint, Algorithmica, vol.19, issue.4, pp.427-446, 1997. ,
DOI : 10.1007/PL00009182
Approximating the 2-interval pattern problem, ESA'05, pp.426-437, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-00619979
Decomposition algorithms for the tree edit distance problem, Journal of Discrete Algorithms, vol.3, issue.2-4, pp.448-471, 2005. ,
DOI : 10.1016/j.jda.2004.08.018
URL : https://hal.archives-ouvertes.fr/hal-00307523
Algorithms and Complexity for Annotated Sequences Analysis, 1999. ,
A polynomial algorithm for comparing RNA secondary structures using a full set of operations ,
A General Edit Distance between RNA Structures, Journal of Computational Biology, vol.9, issue.2, pp.371-388, 2002. ,
DOI : 10.1089/10665270252935511
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.23.5161
The longest common subsequence problem for arc-annotated sequences, Journal of Dicrete Algorithms, pp.257-270, 2004. ,
Alignment of trees ??? an alternative to tree edit, Theoretical Computer Science, vol.143, issue.1, pp.137-148, 1995. ,
DOI : 10.1016/0304-3975(95)80029-9
Computing the Edit-Distance Between Unrooted Ordered Trees, 6th European Symposium on Algorithms, pp.91-102, 1998. ,
DOI : 10.1007/3-540-68530-8_8
The longest common subsequence problem for sequences with nested arc annotations, Journal of Computer and System Sciences, vol.65, issue.3, pp.465-480, 2002. ,
DOI : 10.1016/S0022-0000(02)00004-1
Edit distance between two RNA structures, Proceedings of the fifth annual international conference on Computational biology , RECOMB '01, pp.211-220, 2001. ,
DOI : 10.1145/369133.369214
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.32.7919
Computing similarity between RNA structures, Theoretical Computer Science, vol.276, issue.1-2, pp.111-132, 2002. ,
DOI : 10.1016/S0304-3975(01)00192-X
URL : http://doi.org/10.1016/s0304-3975(01)00192-x
The Tree-to-Tree Correction Problem, Journal of the ACM, vol.26, issue.3, pp.422-433, 1979. ,
DOI : 10.1145/322139.322143
On the computational complexity of 2-interval pattern matching problems, Theoretical Computer Science, vol.312, issue.2-3, pp.223-249, 2004. ,
DOI : 10.1016/j.tcs.2003.08.010
Simple Fast Algorithms for the Editing Distance between Trees and Related Problems, SIAM Journal on Computing, vol.18, issue.6, pp.1245-1262, 1989. ,
DOI : 10.1137/0218082
