HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Nonlinear control for linear motors with friction - Application to an inverted pendulum system
Samer Riachy 1, 2 Thierry Floquet 2, 3 Jean-Pierre Richard 2, 3
2 ALIEN - Algebra for Digital Identification and Estimation
Inria Lille - Nord Europe, Inria Saclay - Ile de France, Centrale Lille, X - École polytechnique, CNRS - Centre National de la Recherche Scientifique : UMR8146
3 SyNeR - Systèmes Non Linéaires et à Retards
CRIStAL - Centre de Recherche en Informatique, Signal et Automatique de Lille - UMR 9189
Abstract : A linear motor is used here as an actuator for a cart-pendulum system. The global, upward stabilization of the inverted position is aimed at. In such an under-actuated situation, (i) constraints on the motor motion (limited length) have to be taken into account and (ii) friction effects may have a strong influence (limit cycles). A two-step path planning-plus-tracking strategy allows for dealing with constraint (i). Regarding point (ii), and since friction effects are hardly modeled, a second-order sliding mode algorithm is chosen. The resulting controller is designed without any knowledge of neither the electromagnetic circuits of the linear motor (the model is a simple gain), nor the friction models (only upper bounds for the friction forces acting on both the linear motor and pendulum are required). Experimental results show good performances in tracking and regulation, both for the swing-up and stabilization phases of the inverted pendulum.
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/inria-00179778
Contributor : Jean-Pierre Richard Connect in order to contact the contributor
Submitted on : Tuesday, October 16, 2007 - 4:05:20 PM
Last modification on : Wednesday, March 23, 2022 - 3:51:21 PM
Long-term archiving on: : Sunday, April 11, 2010 - 11:08:51 PM
File
LDIA07_final.pdf
Identifiers
  • HAL Id : inria-00179778, version 1
Collections
Citation
Samer Riachy, Thierry Floquet, Jean-Pierre Richard. Nonlinear control for linear motors with friction - Application to an inverted pendulum system. LDIA'07, 6th Internat. Symposium on Linear Drives for Industry Applications, Sep 2007, Lille, France. ⟨inria-00179778⟩
Share
Metrics
Record views
291
Files downloads
1180
