Finiteness properties for Pisot $S$-adic tilings
In this paper, we will first formulate and prove some equivalent sufficient conditions to obtain the tiling property for a Pisot unimodular substitution. We will then apply these condition to the more general framework of adic systems, to extend to this more general (and non algebraic) case results already known for the substitutive case.
Mathématique discrète [cs.DM]
