An Aspect-Based Approach to Early Design Modeling, IEEE Proceedings -Software, Special Issue on Early Aspects: Aspect-Oriented Requirements Engineering and Architecture Design, pp.173-185, 2004. ,
Introduction to the Special Issue on Software Architecture, IEEE Transactions on Software Engineering, vol.21, issue.4, 1995. ,
An Introduction To Software Architecture Software Architecture: a Roadmap, Advances in Software Engineering The Future of Software Engineering, International Conference on Software Engineering (ICSE'2000), pp 93-101, pp.1-40, 1993. ,
Model Composition Directives, Proceedings of the International Conference on the UML, pp.84-97, 2004. ,
DOI : 10.1007/978-3-540-30187-5_7
System Structure for Software Fault Tolerance, IEEE Transactions on Software Engineering, issue.12, pp.220-232, 1975. ,
The Evolution of the Recovery Block Concept, Sofware Fault Tolerance, 1995. ,
A Program Structure for Error Detection and Recovery, Proceedings Conference Operating Systems: Theoretical and Practical Aspects, pp.23-25, 1974. ,
An Aspect- Based Approach to Modeling Access Control Concerns, Information and Software Technology, pp.557-633, 2004. ,
Performance Analysis of UML Models Using Aspect-Oriented Modeling Techniques ,
DOI : 10.1007/11557432_12
Towards an Object-Oriented Approach to Software Fault Tolerance Applying Objet Oriented Construction to Fault Tolerant Systems, 1994. ,
Fault Tolerance Principles and Practice, 1981. ,
UML Components, A simple Process for Specifying Component-Based Software, 2001. ,
Aspect-Oriented Analysis and Design: The Theme Approach, 2005. ,
