{An adaptive simulated annealing cooling schedule for object detection in images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mathias Ortner
  • Fonction : Auteur
  • PersonId : 1109838
  • IdRef : 085765023
Xavier Descombes
Josiane Zerubia
  • Fonction : Auteur
  • PersonId : 833424
In our image processing applications, we use a simulated annealing procedure to find configurations of geometric shapes that fit the best an image. This type of algorithm allows finding one of the global minima of an arbitrary function provided that the cooling schedule is logarithmic with the time. Since this type of cooling schedules is very slow, geometrical cooling schemes are used in practice. Geometrical schemes are however subject to some disadvantages that we discuss in this report. To overcome these disadvantages, we propose an adaptive cooling scheme. This heuristic is based on the analysis of the cooling scheme behavior in practice. In particular, we observe the presence of critical temperatures. To deal with these critical temperatures, we propose a cooling scheme that decelerates when such a temperature is detected, and accelerates otherwise. We present results on a real problem taken from our image processing applications.
RR-6336.pdf (626.05 Ko) Télécharger le fichier
inria-00181764 , version 1 (24-10-2007)
inria-00181764 , version 2 (26-10-2007)
inria-00181764 , version 3 (29-10-2007)
inria-00181764 , version 4 (31-10-2007)
inria-00181764 , version 5 (09-11-2007)
  • HAL Id : inria-00181764 , version 2
Mathias Ortner, Xavier Descombes, Josiane Zerubia. {An adaptive simulated annealing cooling schedule for object detection in images. [Research Report] RR-6336, 2007. ⟨inria-00181764v2⟩
Collections
INRIA-RRRT
297 Consultations
1908 Téléchargements
