Multi-sensor data fusion using Bayesian programming: An automotive application, Intelligent Vehicle Symposium, 2002. IEEE, 2002. ,
DOI : 10.1109/IVS.2002.1187989
Using bayesian programming for multi-sensor multitarget tracking in automotive applications, Proc. Int'l. Conf. Robotics and Automation, 2003. ,
URL : https://hal.archives-ouvertes.fr/hal-00068773
The design and implementation of a Bayesian CAD modeler for robotic applications, Advanced Robotics, vol.9, issue.4, pp.45-70, 2001. ,
DOI : 10.1163/156855301750095578
URL : https://hal.archives-ouvertes.fr/hal-00019182
Multisensor on-the-fly localization:, Robotics and Autonomous Systems, vol.34, issue.2-3, pp.131-143, 2001. ,
DOI : 10.1016/S0921-8890(00)00117-2
Stochastic processes and filtering theory, 1970. ,
Multitarget-multisensor tracking: application and advances, 2000. ,
A formulation of multitarget tracking as an incomplete data problem, IEEE Transactions on Aerospace and Electronic Systems, vol.33, issue.4, pp.1242-1257, 1997. ,
DOI : 10.1109/7.625121
Design and analysis of modern tracking systems, 1999. ,
Online simultaneous localization and mapping with detection and tracking of moving objects: theory and results from a ground vehicle in crowded urban areas, Proc. Int'l. Conf. Robotics and Automation, pp.842-849, 2003. ,
Sensor Fusion in Certainty Grids for Mobile Robots, AI Magazine, vol.9, pp.61-74, 1988. ,
DOI : 10.1007/978-3-642-74567-6_19
Using occupancy grids for mobile robot perception and navigation, Computer, vol.22, issue.6, pp.46-57, 1989. ,
DOI : 10.1109/2.30720
Tracking multiple moving objects for real-time robot navigation, Journal of Autonomous Robots, Special Issue on Perception for Mobile Agents, vol.8, 2000. ,
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, 1960. ,
DOI : 10.1115/1.3662552
Pictorial Structures for Object Recognition, International Journal of Computer Vision, vol.61, issue.1, pp.55-79, 2005. ,
DOI : 10.1023/B:VISI.0000042934.15159.49
People Tracking with Mobile Robots Using Sample-Based Joint Probabilistic Data Association Filters, The International Journal of Robotics Research, vol.22, issue.2, pp.99-116, 2003. ,
DOI : 10.1177/0278364903022002002
Probabilistic data association methods for tracking complex visual objects, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.6, pp.560-576, 2001. ,
DOI : 10.1109/34.927458
Suboptimal joint probabilistic data association, IEEE Transactions on Aerospace and Electronic Systems, vol.29, issue.2, pp.510-517, 1993. ,
DOI : 10.1109/7.210087
Together with Fig.2. Tracking sequence based on the data from CAVIAR. The first column shows the input image with the bounding boxes indicating detected humans. Second column and third column shows the corresponding representation of the BOF and JPDA tracker respectively ,
