Feature Selection For Self-Supervised Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2005
Pierre Bessiere
Anne Spalanzani
A foundation of the developmental approach to robotics is that learning must be grounded on sensorimotor interaction. In order to behave autonomously, a robot has to build its own model of the world by searching and exploiting statistical regularities in his sensorimotor domain. Self-supervised learning consists in relying on previous knowledge to acquire new skills. We propose to mix self-supervised learning with our probabilistic programming method, the Bayesian Robot Programming Framework. This idea corresponds to achieve feature selection for searching for relevant sensors. We compare several feature selection algorithms and validate them on a real robotic experiment
Autre [cs.OH]
dangauthier05devrob.pdf (129.56 Ko) Télécharger le fichier
inria-00182037 , version 1 (24-10-2007)
  • HAL Id : inria-00182037 , version 1
Pierre Dangauthier, Pierre Bessiere, Anne Spalanzani. Feature Selection For Self-Supervised Learning. [Technical Report] 2005. ⟨inria-00182037⟩
192 Consultations
283 Téléchargements
