Online Reconstruction Of Vehicles In A Car Park - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
In this paper, a method of obtaining vehicle hypothesis based on laser scan data only is proposed. This is implemented on the robotic vehicle, CyCab, for navigation and mapping of the static car park environment. Laser scanner data is used to obtain hypothesis on position and orientation of vehicles with Bayesian Programming. Using the hypothesized vehicle poses as landmarks, CyCab performs Simultaneous Localization And Mapping (SLAM). A final map consisting of the vehicle positions in the car park is obtained.
Autre [cs.OH]
TPL05.pdf (179.27 Ko) Télécharger le fichier
inria-00182042 , version 1 (24-10-2007)
Christopher Tay, Cédric Pradalier, Christian Laugier. Online Reconstruction Of Vehicles In A Car Park. Proc. of the Int. Conf. on Field and Service Robotics, Jul 2005, Port Douglas Australia, Australia. pp.207-218, ⟨10.1007/978-3-540-33453-8_18⟩. ⟨inria-00182042⟩
138 Consultations
379 Téléchargements
