Dp-slam: Fast, robust simultaneous localization and mapping without ,
An Atlas framework for scalable mapping, 2003 IEEE International Conference on Robotics and Automation (Cat. No.03CH37422), 2003. ,
DOI : 10.1109/ROBOT.2003.1241872
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.13.5136
Representation issues, 2002. ,
Maximum likelihood from incomplete data via the em algorithm, Journal of Royal Statistical Society B, vol.39, pp.1-38, 1977. ,
Rao-blackwellised particle filters for dynamic bayes net ,
Random sample consensus: A paradigm for model fitting with applications to image analysis and automated cartography ,
A New Approach to Linear Filtering and Prediction Problems, Journal of Basic Engineering, vol.82, issue.1, pp.35-45, 1960. ,
DOI : 10.1115/1.3662552
Towards constant time SLAM using postponement, Proceedings 2001 IEEE/RSJ International Conference on Intelligent Robots and Systems. Expanding the Societal Role of Robotics in the the Next Millennium (Cat. No.01CH37180) ,
DOI : 10.1109/IROS.2001.973391
Detection et suivi de vehicules par telemetri laser en robotique autonome, Institut National Polytechnique Grenoble (INPG), INRIA Rhone Alpes (GRAVIR), 2003. ,
Fastslam: A factored solution to the simultaneous localization and mapping problem, 2002. ,
Fastslam 2.0: An improved particle filtering algorithm for simultaneous localization and mapping that provably converges ,
Bayesian map learning in dynamic environments ,
Data association in stochastic mapping using the joint compatibility test, IEEE Transactions on Robotics and Automation, vol.17, issue.6, pp.890-897, 2001. ,
DOI : 10.1109/70.976019
Probabilistic state estimation of dynamic objects with a moving mobile robot, Robotics and Autonomous Systems, vol.34, issue.2-3, 2001. ,
DOI : 10.1016/S0921-8890(00)00115-9
Estimating uncertain spatial relationships in robotics, Proceedings. 1987 IEEE International Conference on Robotics and Automation, 1990. ,
DOI : 10.1109/ROBOT.1987.1087846
On the Representation and Estimation of Spatial Uncertainty, The International Journal of Robotics Research, vol.5, issue.4, 1985. ,
DOI : 10.1177/027836498600500404
Data association in slam, 2002. ,
Robust Mapping and Localization in Indoor Environments Using Sonar Data, The International Journal of Robotics Research, vol.21, issue.4, pp.331-331, 2002. ,
DOI : 10.1177/027836402320556340
A Probabilistic On-Line Mapping Algorithm for Teams of Mobile Robots, The International Journal of Robotics Research, vol.20, issue.5, pp.335-363, 2001. ,
DOI : 10.1177/02783640122067435
A real-time algorithm for mobile robot mapping with applications to multi-robot and 3D mapping, Proceedings 2000 ICRA. Millennium Conference. IEEE International Conference on Robotics and Automation. Symposia Proceedings (Cat. No.00CH37065), 2000. ,
DOI : 10.1109/ROBOT.2000.844077
A probabilistic approach to concurrent mapping and localization for mobile robots, Machine Learning, pp.29-53, 1998. ,
Exploration and model building in mobile robot domains, IEEE International Conference on Neural Networks, 1993. ,
DOI : 10.1109/ICNN.1993.298552
Spatial learning for navigation in dynamic environments, IEEE Transactions on Systems, Man and Cybernetics, Part B (Cybernetics), vol.26, issue.3, 1996. ,
DOI : 10.1109/3477.499799
Qualitative and quantitative car tracking from a range image sequence, International Conference on Computer Vision and Pattern Recognition (CVPR'98), pp.496-501, 1998. ,
