New interface
Reports (Research report)
Long-Run Cost Analysis by Approximation of Linear Operators over Dioids
David Cachera 1 Thomas Jensen 1 Arnaud Jobin 1 Pascal Sotin 1
1 Lande - Logiciel : ANalyse et DEveloppement
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : We present a static analysis technique for modeling and approxi- mating the long-run resource usage of programs. The approach is based on a quantitative semantic framework where programs are represented as linear op- erators over dioids. We show how to extract the long-run cost of a program from the matrix representation of its semantics. An essential contribution is to provide abstraction techniques which make it feasible to compute safe over- approximations of this cost. A theorem is proved stating that such abstractions yield correct approximations of the program's long-run cost. The theoretical developments are illustrated on a concrete example taken from the analysis of the cache behaviour of a simple bytecode language.
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/inria-00182338
Contributor : David Cachera Connect in order to contact the contributor
Submitted on : Friday, January 25, 2008 - 12:14:56 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:36 AM
Long-term archiving on: : Friday, November 25, 2016 - 8:48:20 PM
RR-6338.pdf
Identifiers
  • HAL Id : inria-00182338, version 4
Citation
David Cachera, Thomas Jensen, Arnaud Jobin, Pascal Sotin. Long-Run Cost Analysis by Approximation of Linear Operators over Dioids. [Research Report] RR-6338, INRIA. 2007, pp.35. ⟨inria-00182338v4⟩
Share
Metrics
Record views
330
Files downloads
239
