Matches for instance the sequenceGTTGAGAGGTTGA This model includes the two types of string variables ( , called mute variable, and X) It matches the sequence with X= "GTTGA" (both mute variable values empty) and also with X= "GTT". As in Prolog two mute variables correspond to different variables and may have different values It is useful for describing gaps ,
Matches for instance "TCGCGA" with X="TCG". This model describes a biological palindrome. It includes an occurrence of X, followed by a transformation of X by a reverse morphism (direction -) described by non-terminal wc ,
Matches for instance "GATTGAGATT, Here ,
TAGTAT Matches for instance the sequence "CCTAGTATCCGATAC". This model states that to be admissible, a sequence must at the same time contains "ATCCGA" and "TAGTAG ,
Basic local alignment search tool, Journal of Molecular Biology, vol.215, issue.3, pp.403-410, 1990. ,
DOI : 10.1016/S0022-2836(05)80360-2
Finding patterns common to a set of strings (Extended Abstract), Proceedings of the eleventh annual ACM symposium on Theory of computing , STOC '79, pp.130-141, 1979. ,
DOI : 10.1145/800135.804406
Kangaroo -a pattern-matching program for biological sequences, BMC Bioinformatics, vol.3, issue.1, p.20, 2002. ,
DOI : 10.1186/1471-2105-3-20
Palingol: a declarative programming language to describe nucleic acids' secondary structures and to scan sequence database, Nucleic Acids Research, vol.24, issue.8, 1996. ,
DOI : 10.1093/nar/24.8.1395
A pattern language for molecular biology, 1995. ,
Genome structure described by formal languages, Nucleic Acids Research, vol.12, issue.5, pp.2561-2568, 1984. ,
DOI : 10.1093/nar/12.5.2561
A generalized profile syntax for biomolecular sequences motifs and its function in automatic sequence interpretation ,
Synchronized regular expressions, Acta Inf, vol.39, issue.1, pp.31-70, 2003. ,
Gene Structure Prediction by Linguistic Methods, Genomics, vol.23, issue.3, pp.540-551, 1994. ,
DOI : 10.1006/geno.1994.1541
Evaluation of several lightweight stochastic contextfree grammars for RNA secondary structure prediction, BMC Bioinformatics, vol.5, 2004. ,
A constraint based structure description language for biosequences, Constraints, vol.6, issue.2/3, pp.173-200, 2001. ,
DOI : 10.1023/A:1011481521835
HyPaLib: a database of RNAs and RNA structural elements defined by hybrid patterns, Nucleic Acids Research, vol.29, issue.1, pp.196-198, 2001. ,
DOI : 10.1093/nar/29.1.196
RNA modeling using gibbs sampling and stochastic context free grammars, Proceedings of the Second International Conference on Intelligent Systems for Molecular Biology, pp.1501-1531, 1994. ,
PALM -A pattern language for molecular biology, Proceedings of the First International Conference on Intelligent Systems for Molecular Biology(ISMB-93), pp.172-180, 1993. ,
The convergence of midly context-sensitive grammars, The Processing of Natural Language Structure, pp.31-81, 1991. ,
Basic Gene Grammars and DNA-ChartParser for language processing of Escherichia coli promoter DNA sequences, Bioinformatics, vol.17, issue.3, pp.226-236, 2001. ,
DOI : 10.1093/bioinformatics/17.3.226
A linguistic model for the rational design of antimicrobial peptides, Nature, vol.78, issue.7113, pp.867-869, 2006. ,
DOI : 10.1038/nature05233
Overlapping genes in vertebrate genomes, Computational Biology and Chemistry, vol.29, issue.1, pp.1-12, 2005. ,
DOI : 10.1016/j.compbiolchem.2004.12.006
tacg -a grep for dna, BMC Bioinformatics, vol.3, issue.8, 2002. ,
Pattern locator: a new tool for finding local sequence patterns in genomic DNA sequences, Bioinformatics, vol.22, issue.24, pp.3099-3100, 2006. ,
DOI : 10.1093/bioinformatics/btl551
Hardness results for the center and median string problems under the weighted and unweighted edit distances, Journal of Discrete Algorithms, vol.3, issue.2-4, pp.390-415, 2005. ,
DOI : 10.1016/j.jda.2004.08.015
URL : https://hal.archives-ouvertes.fr/lirmm-00105320
Suffix-tree analyser (STAN): looking for nucleotidic and peptidic patterns in chromosomes, Bioinformatics, vol.21, issue.24, pp.4408-4410, 2005. ,
DOI : 10.1093/bioinformatics/bti710
Combinatorial approaches to finding subtle signals in dna sequences, Proceedings of the Eighth International Conference on Intelligent Systems for Molecular Biology, pp.269-278, 2000. ,
An efficient algorithm for solving word equations, Proceedings of the thirty-eighth annual ACM symposium on Theory of computing , STOC '06, pp.467-476, 2006. ,
DOI : 10.1145/1132516.1132584
Applications in constraint logic programming with strings, Principles and Practice of Constraint Programming, pp.109-122, 1994. ,
DOI : 10.1007/3-540-58601-6_94
EMBOSS: The European Molecular Biology Open Software Suite, Trends in Genetics, vol.16, issue.6, pp.276-277, 2000. ,
DOI : 10.1016/S0168-9525(00)02024-2
Recent methods for RNA modeling using stochastic context-free grammars, Proceedings of the Asilomar Conference on Combinatorial Pattern Matching, pp.289-306, 1994. ,
DOI : 10.1007/3-540-58094-8_25
RNA MODELING BY COMBINING STOCHASTIC CONTEXT-FREE GRAMMARS AND n-GRAM MODELS, International Journal of Pattern Recognition and Artificial Intelligence, vol.16, issue.03, pp.309-315, 2002. ,
DOI : 10.1142/S0218001402001691
Formal grammars for intermolecular structure, Proceedings First International Symposium on Intelligence in Neural and Biological Systems. INBS'95, pp.30-37, 1995. ,
DOI : 10.1109/INBS.1995.404291
String variable grammar: A logic grammar formalism for the biological language of DNA, The Journal of Logic Programming, vol.24, issue.1-2, pp.73-102, 1995. ,
DOI : 10.1016/0743-1066(95)00034-H
A SYNTACTIC PATTERN RECOGNITION SYSTEM FOR DNA SEQUENCES, Bioinformatics, Supercomputing and Complex Genome Analysis, pp.89-101, 1993. ,
DOI : 10.1142/9789814503655_0008
The syntax and semantics of a language for describing complex patterns in biological sequences, 2000. ,
Grammatically modeling and predicting RNA secondary structures, Proceedings of 6th Genome Informatics Workshop, pp.67-76, 1995. ,
Campus universitaire de Beaulieu -35042 Rennes Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4 ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès-Nancy Cedex (France) Unité de recherche INRIA Rhône-Alpes : 655, avenue de l'Europe -38334 Montbonnot Saint-Ismier (France) Unité de recherche INRIA Rocquencourt : Domaine de Voluceau -Rocquencourt -BP 105 -78153 Le Chesnay Cedex (France) Unité de recherche, 2004. ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
