Reports
Network Coding for Wireless Broadcast: Rate Selection with Dynamic Heuristics
Song Yean Cho 1 Cédric Adjih 1
1 HIPERCOM - High performance communication
Inria Paris-Rocquencourt, UP11 - Université Paris-Sud - Paris 11, Inria Saclay - Ile de France, X - École polytechnique, CNRS - Centre National de la Recherche Scientifique : UMR
Abstract : Network coding is a novel method for transmitting data, which has been recently proposed, and has been shown to have potential to improve wireless network performance. In this article, we study using network coding for one specific case of multicast, broadcasting. Precisely, we focus on (energy-)efficient broadcasting in a multi-hop wireless networks: transmitting data from one source to all nodes with a small number of retransmissions. It is known that finding an efficient method to broadcast, is essentially summarized in selecting proper transmission rates of each node. Our contribution, is proposing a simple and efficient method for determining a rate selection. Our method adapts dynamically and uses only local dynamic information of neighbors: Dynamic Rate Adaptation from Gap with Other Nodes (D.R.A.G.O.N.). The rationale of this rate selection method is detailed from some logical arguments. Experimental results illustrate the behavior of the method, and its excellent performance.
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/inria-00186577
Contributor : Rapport de Recherche Inria Connect in order to contact the contributor
Submitted on : Tuesday, November 13, 2007 - 2:51:08 PM
Last modification on : Tuesday, February 9, 2021 - 8:52:02 PM
Long-term archiving on: : Friday, November 25, 2016 - 6:36:34 PM
RR-6349.pdf
Identifiers
  • HAL Id : inria-00186577, version 2
Collections
Citation
Song Yean Cho, Cédric Adjih. Network Coding for Wireless Broadcast: Rate Selection with Dynamic Heuristics. [Research Report] RR-6349, INRIA. 2007. ⟨inria-00186577v2⟩
Share
Metrics
Record views
492
Files downloads
180
