The automatic acquisition of verb subcategorisations and their impact on the performance of an HPSG parser, Proceedings of the 1st International Joint Conference on Natural Language Processing (IJCNLP), pp.107-114, 2004. ,
Extraction d'information de sous-catégorisation à partir des tables du LADL, Proceedings of TALN 06, pp.139-148, 2006. ,
The Lefff 2 syntactic lexicon for French : architecture, acquisition, use, Actes de LREC 06, 2006. ,
Le DAFLES, un nouveau dictionnaire pour apprenants du français, Actes du dixième congrès EURALEX'2002 (European Association for Lexicography). Copenhague, 2002. ,
On UNL as the future "html of the linguistic content" and the reuse of existing NLP components in UNL-related applications with the example of a UNL-French deconverter, Proceedings of COLING 2000, 2000. ,
La valence : l'approche pronominale et son application au lexique verbal, Journal of French Language Studies, pp.63-104, 2002. ,
