Measurement of fiber orientation distributions using high angular resolution diffusion imaging, Magnetic Resonance in Medicine, vol.77, issue.5, pp.1194-1206, 2005. ,
DOI : 10.1002/mrm.20667
Connectivity-Based Parcellation of Broca's Area, Cerebral Cortex, vol.17, issue.4, pp.816-825, 2007. ,
DOI : 10.1093/cercor/bhk034
Log-Euclidean metrics for fast and simple calculus on diffusion tensors, Magnetic Resonance in Medicine, vol.52, issue.2, pp.411-421, 2006. ,
DOI : 10.1002/mrm.20965
URL : https://hal.archives-ouvertes.fr/inria-00502678
Microstructural and Physiological Features of Tissues Elucidated by Quantitative-Diffusion-Tensor MRI, Journal of Magnetic Resonance, Series B, vol.111, issue.3, pp.209-219, 1996. ,
DOI : 10.1006/jmrb.1996.0086
Estimation of the Effective Self-Diffusion Tensor from the NMR Spin Echo, Journal of Magnetic Resonance, Series B, vol.103, issue.3, pp.247-254, 1994. ,
DOI : 10.1006/jmrb.1994.1037
URL : https://hal.archives-ouvertes.fr/hal-00349722
MR diffusion tensor spectroscopy and imaging, Biophysical Journal, vol.66, issue.1, pp.259-267, 1994. ,
DOI : 10.1016/S0006-3495(94)80775-1
URL : https://hal.archives-ouvertes.fr/hal-00349721
In vivo fiber tractography using DT-MRI data, Magnetic Resonance in Medicine, vol.40, issue.4, pp.625-632, 2000. ,
DOI : 10.1002/1522-2594(200010)44:4<625::AID-MRM17>3.0.CO;2-O
Fiber tract following in the human brain using dt-mri data, IEICE TRANSACTIONS on Information and Systems (Special Issue on Measurements and Visualization Technology of Biological Information), issue.1, pp.85-100, 2002. ,
Non-invasive mapping of connections between human thalamus and cortex using diffusion imaging, Nature Neuroscience, vol.6, issue.5, pp.750-757, 2003. ,
Characterization and propagation of uncertainty in diffusion-weighted MR imaging, Magnetic Resonance in Medicine, vol.36, issue.5, pp.1077-1088, 2003. ,
DOI : 10.1002/mrm.10609
MR Diffusion Tractography: Methods and Applications, p.28, 2004. ,
Laplacian eigenmaps for dimensionality reduction and data representation, Neural Computation, vol.15, issue.20, pp.1373-1396, 2003. ,
Charting a manifold, 2003. ,
Coloring of DT-MRI Fiber Traces Using Laplacian Eigenmaps, Computer Aided Systems Theory -EUROCAST, pp.518-529, 2003. ,
DOI : 10.1007/978-3-540-45210-2_47
Characterization of anisotropy in high angular resolution diffusion-weighted mri, Magn Reson Med, vol.47, issue.6, pp.1083-1099, 2002. ,
Fmrib software library Anatomy of the human body, Bartleby.com, issue.5, p.33, 1918. ,
Understanding Diffusion MR Imaging Techniques: From Scalar Diffusion-weighted Imaging to Diffusion Tensor Imaging and Beyond, RadioGraphics, vol.26, issue.suppl_1, pp.205-223, 2006. ,
DOI : 10.1148/rg.26si065510
Q-ball reconstruction of multimodal fiber orientations using the spherical harmonic basis, Magnetic Resonance in Medicine, vol.54, issue.1, pp.104-117, 2006. ,
DOI : 10.1002/mrm.20931
Data clustering: a review, ACM Computing Surveys, vol.31, issue.3, pp.264-323, 1999. ,
DOI : 10.1145/331499.331504
Modeling cerebral connectivity and low grade glioma invasion using diffusion tensor imaging, p.28, 2006. ,
Improved Optimization for the Robust and Accurate Linear Registration and Motion Correction of Brain Images, NeuroImage, vol.17, issue.2, pp.825-841, 2002. ,
DOI : 10.1006/nimg.2002.1132
Principal component analysis, p.15, 1986. ,
DOI : 10.1007/978-1-4757-1904-8
A level set method for segmentation of the thalamus and its nuclei in DT-MRI, Special Issue of Signal Processing on Diffuision Tensor Imaging, pp.309-321, 2007. ,
DOI : 10.1016/j.sigpro.2005.12.017
Optimal strategies for measuring diffusion in anisotropic systems by magnetic resonance imaging, Magnetic Resonance in Medicine, vol.8, issue.3, pp.515-525, 1999. ,
DOI : 10.1002/(SICI)1522-2594(199909)42:3<515::AID-MRM14>3.0.CO;2-Q
Isotropic resolution diffusion tensor imaging with whole brain acquisition in a clinically acceptable time, Human Brain Mapping, vol.17, issue.4, pp.216-230, 2002. ,
DOI : 10.1002/hbm.10018
An Investigation of Functional and Anatomical Connectivity Using Magnetic Resonance Imaging, NeuroImage, vol.16, issue.1, pp.241-250, 2002. ,
DOI : 10.1006/nimg.2001.1052
Diffusion maps and coarse-graining: a unified framework for dimensionality reduction , graph partitioning, and data set parameterization. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.28, issue.23, pp.1393-1403, 1920. ,
Bootstrap white matter tractography (BOOT-TRAC), NeuroImage, vol.24, issue.2, pp.524-532, 2005. ,
DOI : 10.1016/j.neuroimage.2004.08.050
Imagerie de diffusion in vivo par résonnance magnétique nucléaire, CR Académie des Sciences, issue.301 5, pp.1109-1112, 1985. ,
Control Theory and Fast Marching Techniques for Brain Connectivity Mapping, 2006 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, Volume 1 (CVPR'06), 2006. ,
DOI : 10.1109/CVPR.2006.89
URL : https://hal.archives-ouvertes.fr/inria-00377403
The Laplacian on a Riemannian Manifold: An Introduction to Analysis on Manifolds, p.46, 1997. ,
DOI : 10.1017/CBO9780511623783
Nonlinear Dimensionality Reduction by Locally Linear Embedding, Science, vol.290, issue.14, pp.2323-2326, 2000. ,
Think Globally, Fit Locally: Unsupervised Learning of Low Dimensional Manifolds, Journal of Machine Learning Research, vol.4, issue.2 6, pp.119-155, 2003. ,
Normalized cuts and image segmentation. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.22, issue.32, pp.888-905, 2000. ,
Spin Diffusion Measurements: Spin Echoes in the Presence of a Time???Dependent Field Gradient, The Journal of Chemical Physics, vol.42, issue.1, pp.288-292, 1965. ,
DOI : 10.1063/1.1695690
Co-Planar Stereotaxic Atlas of the Human Brain: 3- Dimensional Proportional System : An Approach to Cerebral Imaging, p.33, 1988. ,
The spatial mapping of translational diffusion coefficients by the NMR imaging technique, Physics in Medicine and Biology, vol.30, issue.4, pp.345-349, 1985. ,
DOI : 10.1088/0031-9155/30/4/009
A Global Geometric Framework for Nonlinear Dimensionality Reduction, Science, vol.290, issue.5500, pp.2902319-2902334, 2000. ,
DOI : 10.1126/science.290.5500.2319
Naftali Tishby and Noam Slonim. Data clustering by markovian relaxation and the information bottleneck method, Neural Information Processing Systems, p.34, 2000. ,
Variational frameworks for DT-MRI estimation, regularization and visualization, Proceedings Ninth IEEE International Conference on Computer Vision, pp.116-121, 2003. ,
DOI : 10.1109/ICCV.2003.1238323
High angular resolution diffusion imaging reveals intravoxel white matter fiber heterogeneity, Magnetic Resonance in Medicine, vol.147, issue.4, pp.577-582, 2002. ,
DOI : 10.1002/mrm.10268
Q-ball imaging, Magnetic Resonance in Medicine, vol.23, issue.6, pp.1358-1372, 2004. ,
DOI : 10.1002/mrm.20279
Simultaneous smoothing and estimation of the tensor field from diffusion tensor MRI, 2003 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, 2003. Proceedings., pp.461-466, 2003. ,
DOI : 10.1109/CVPR.2003.1211390
A Constrained Variational Principle for Direct Estimation and Smoothing of the Diffusion Tensor Field From Complex DWI, IEEE Transactions on Medical Imaging, vol.23, issue.8, pp.930-939, 2004. ,
DOI : 10.1109/TMI.2004.831218
Segmentation using eigenvectors: a unifying view, Proceedings of the Seventh IEEE International Conference on Computer Vision, pp.975-982, 1999. ,
DOI : 10.1109/ICCV.1999.790354
Processing and visualization for diffusion tensor MRI, Medical Image Analysis, vol.6, issue.2, pp.93-108, 2002. ,
DOI : 10.1016/S1361-8415(02)00053-1
Ulas Ziyan, David Tuch, and Carl-Fredrik Westin. Segmentation of thalamic nuclei from dti using spectral clustering, Medical Image Computing and Computer-Assisted Intervention, pp.807-814, 2006. ,
route des Lucioles -BP 93 -06902 Sophia Antipolis Cedex (France) Unité de recherche INRIA Futurs : Parc Club Orsay Université -ZAC des Vignes 4, 2004. ,
Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 Villers-lès ,
BP 105 -78153 Le Chesnay Cedex (France) http://www.inria.fr ISSN, pp.249-6399 ,
