Goodness-of-fit Tests for high-dimensional Gaussian linear models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Let $(Y,(X_i)_{i\in\mathcal{I}})$ be a zero mean Gaussian vector and $V$ be a subset of $\mathcal{I}$. Suppose we are given $n$ i.i.d. replications of the vector $(Y,X)$. We propose a new test for testing that $Y$ is independent of $(X_i)_{i\in \mathcal{I}\backslash V}$ conditionally to $(X_i)_{i\in V}$ against the general alternative that it is not. This procedure does not depend on any prior information on the covariance of $X$ or the variance of $Y$ and applies in a high-dimensional setting. It straightforwardly extends to test the neighbourhood of a Gaussian graphical model. The procedure is based on a model of Gaussian regression with random Gaussian covariates. We give non asymptotic properties of the test and we prove that it is rate optimal (up to a possible $\log(n)$ factor) over various classes of alternatives under some additional assumptions. Besides, it allows us to derive non asymptotic minimax rates of testing in this setting. Finally, we carry out a simulation study in order to evaluate the performance of our procedure.
RR-test.pdf (545.24 Ko) Télécharger le fichier
inria-00186919 , version 1 (12-11-2007)
inria-00186919 , version 2 (15-11-2007)
inria-00186919 , version 3 (05-12-2007)
inria-00186919 , version 4 (23-05-2008)
  • HAL Id : inria-00186919 , version 1
  • ARXIV : 0711.2119
Nicolas Verzelen, Fanny Villers. Goodness-of-fit Tests for high-dimensional Gaussian linear models. [Research Report] 2007, pp.46. ⟨inria-00186919v1⟩
293 Consultations
377 Téléchargements
