Using partial differential equations to generate free-form surfaces, Computer-Aided Design, vol.22, pp.202-212, 1990. ,
Implicit fairing of arbitrary meshes using diffusion and curvature flow, SIGGRAPH Proceedings, 1999. ,
Spectral surface quadrangulation, SIGGRAPH '06: ACM SIGGRAPH, 2006. ,
Charms: a simple framework for adaptive simulation, Processings SIGGRAPH, 2002. ,
Computing conformal structures of surfaces, Communications in Information and Systems 2, pp.121-146, 2002. ,
Multiresolution signal processing for meshes, Computer Graphics Proceedings, pp.325-334, 1999. ,
Spectral compression of mesh geometry, SIGGRAPH '00: Proceedings of the 27th annual conference on Computer graphics and interactive techniques, pp.279-286, 2000. ,
GeoFilter: Geometric Selection of Mesh Filter Parameters, Computer Graphics Forum, vol.24, issue.3, pp.295-302, 2005. ,
Localized bi-Laplacian Solver on a Triangle Mesh and Its Applications, 2006. ,
Interactive multi-resolution modeling on arbitrary meshes, SIGGRAPH Conference Proceedings, pp.105-114, 1998. ,
Maps: Multiresolution adaptive parameterization of surfaces, Computer Graphics Proceedings, pp.95-104, 1998. ,
An out-of-core sparse symmetric indefinite factorization method, ACM Transactions on Mathematical Software, vol.32, pp.445-471, 2006. ,
Discrete differential-geometry operators for triangulated 2-manifolds, pp.35-57, 2003. ,
Direct spherical harmonic transform of a triangulated mesh, pp.17-26, 2006. ,
Laplacian mesh optimization, Proceedings of ACM GRAPHITE, pp.381-389, 2006. ,
Spectral processing of point sampled geometry, SIGGRAPH Proceedings, 2001. ,
Computing discrete minimal surfaces and their conjugates, Experimental Mathematics, vol.2, issue.1, 1993. ,
Laplace-spectra as fingerprints for shape matching, SPM '05: Proceedings of the 2005 ACM symposium on Solid and physical modeling, pp.101-106, 2005. ,
Exaggerated shading for depicting shape and detail, Proc. SIGGRAPH), 2006. ,
Discrete differential geometry: an applied introduction, SIGGRAPH Course Notes, 2005. ,
Efficient spectral watermarking of large meshes with orthogonal basis functions, The Visual Computer, 2005. ,
3d surface filtering using spherical harmonics, In Computer-Aided Design, vol.36, p.363375, 2004. ,
