Conference papers
Triangulation of uniform particle systems: its application to the implicit surface texturing
Florian Levet 1, 2 Xavier Granier 1, 2, * Christophe Schlick 1, 2
* Corresponding author
1 IPARLA - Visualization and manipulation of complex data on wireless mobile devices
INRIA Futurs, Université Sciences et Technologies - Bordeaux 1, École Nationale Supérieure d'Électronique, Informatique et Radiocommunications de Bordeaux (ENSEIRB), CNRS - Centre National de la Recherche Scientifique : UMR5800
Abstract : Particle systems, as originally presented by Witkin and Heckbert[WH94], offer an elegant solution to sample implicit surfaces of arbitrary genus, while providing an extremely regular distribution of samples over the surface. In this paper, we present an efficient technique that uses particle systems to rapidly generate a triangular mesh over an implicit surface, where each triangle is almost equilateral. The major advantage of such a triangulation is that it minimizes the deformations between the mesh and the underlying implicit surface. We exploit this property by using few triangular texture samples mapped in a non-periodic fashion as presented by Neyret and Cani[NC99]. The result is a pattern-based texturing method that maps homogeneous non-periodic textures to arbitrary implicit surfaces, with almost no deformation.
Document type :
Conference papers
Complete list of metadatas
https://hal.inria.fr/inria-00187181
Contributor : Xavier Granier <>
Submitted on : Sunday, October 27, 2013 - 11:28:18 AM
Last modification on : Monday, November 9, 2020 - 11:22:03 PM
Long-term archiving on: : Tuesday, January 28, 2014 - 4:32:13 AM
Article.pdf
Identifiers
  • HAL Id : inria-00187181, version 2
Collections
Citation
Florian Levet, Xavier Granier, Christophe Schlick. Triangulation of uniform particle systems: its application to the implicit surface texturing. 15th International Conference in Central Europe on Computer Graphics, Visualization and Computer Vision, Jan 2007, Plzen, Czech Republic. ⟨inria-00187181v2⟩
Share
Metrics
Record views
333
Files downloads
648
