Visualization of point-based surfaces with locally reconstructed subdivision surfaces, Shape Modeling International, issue.4, 2005. ,
Reconstruction and representation of 3D objects with radial basis functions, ACM SIGGRAPH, issue.2, 2001. ,
Intelligent balloon, ACM Symposium on Solid Modeling and Applications, issue.2, 2001. ,
Shape reconstruction from 3d and 2d data using pde-based deformable surfaces, ECCV, vol.2, issue.6, 2004. ,
Multiresolution analysis of arbitrary meshes, Proceedings of the 22nd annual conference on Computer graphics and interactive techniques , SIGGRAPH '95, 1995. ,
DOI : 10.1145/218380.218440
On visible surface generation by a priori tree structures, 1980. ,
Surface simplification using quadric error metrics, p.4, 1997. ,
Surface reconstruction based on lower dimensional localized delaunay triangulation, Eurographics, vol.3, issue.2, p.7, 2000. ,
Surface reconstruction from unorganized points, ACM SIGGRAPH, vol.3, issue.2 5, 1992. ,
Piecewise smooth surface reconstruction, 1994. ,
Oct-trees and their use in representing three-dimensional objects, CGIP, vol.14, issue.2, 1980. ,
Smooth subdivisions surfaces based on triangles, 1987. ,
MAPS: Multiresolution adaptive parameterization of surfaces, 1998. ,
Optimization techniques for approximation with subdivision surfaces, ACM Symposium on Solid Modeling and Applications, 2004. ,
Efficiently combining positions and normals for precise 3d geometry, 2005. ,
Multi-level partition of unity implicits, ACM SIG- GRAPH, vol.6, issue.2, p.7, 2003. ,
Spectral processing of pointsampled geometry, ACM SIGGRAPH, vol.4, p.5, 2001. ,
Efficient simplification of point-sampled surfaces, IEEE VIS, vol.2, p.5, 2002. ,
Multi-resolution 3d approximation for rendering complex scenes, Modeling in Computer Graphics, issue.2, 1993. ,
Triangulating point set surfaces with bounded error, Eurographics Symposium on Geometry Processing, issue.5, 2005. ,
Efficient adaptive simplification of messive meshes, IEEE VIS, issue.2, 2001. ,
Subdivision surface fitting to a range of points, Pacific Graphics, issue.2, 1999. ,
Implicit surfaces that interpolate, Shape Modeling International, issue.2, 2002. ,
Multiresolution reconstruction of implicit surfaces with attributes from large unorganized point sets, Shape Modeling International, vol.2, p.7, 2004. ,
Curved pn triangles, 2001. ,
Interactive multiresolution mesh editing, ACM SIGGRAPH, vol.2, issue.6, 1997. ,
