Conic approximation of planar curves, Computer-Aided Design, vol.33, issue.12, pp.867-872, 2001. ,
DOI : 10.1016/S0010-4485(00)00110-X
A Computational Basis for Conic Arcs and Boolean Operations on Conic Polygons, Proc. of European Symposium on Algorithms, pp.174-186, 2002. ,
DOI : 10.1007/3-540-45749-6_19
VorlesungenüberVorlesungen¨Vorlesungenüber Differentialgeometrie II Affine Differential Geometrie, volume VII of Die Grundlehren der mathematischen Wissenschaften in Einzeldarstellungen, 1923. ,
Spline functions and multivariate interpolation, of Mathematics and its Applications, 1993. ,
DOI : 10.1007/978-94-015-8169-1
High accuracy geometric Hermite interpolation, Computer Aided Geometric Design, vol.4, issue.4, pp.269-278, 1987. ,
DOI : 10.1016/0167-8396(87)90002-1
Geometric Hermite Interpolation???, Computer Aided Geometric Design, vol.22, issue.7, pp.573-592, 2005. ,
DOI : 10.1016/j.cagd.2005.06.008
Constructive Approximation, volume 303 of Grundlehren der mathematischen Wissenschaften, 1993. ,
Approximate implicitization, Mathematical Methods in CAGD: Oslo, pp.81-102, 2000. ,
Overview of approximate implicitization, Topics in Algebraic Geometry and Geometric Modelling of Series on Contemporary Mathematics, pp.169-184, 2003. ,
DOI : 10.1090/conm/334/05981
The predicates for the Voronoi diagram of ellipses, Proceedings of the twenty-second annual symposium on Computational geometry , SCG '06, pp.227-236, 2006. ,
DOI : 10.1145/1137856.1137891
A real-time and exact implementation of the predicates for the Voronoi diagram of parametric ellipses, Proceedings of the 2007 ACM symposium on Solid and physical modeling , SPM '07, 2007. ,
DOI : 10.1145/1236246.1236266
Curvature continuity and offsets for piecewise conics, ACM Transactions on Graphics, vol.8, issue.2, pp.89-99, 1989. ,
DOI : 10.1145/62054.62056
Approximation by polygons and polyhedra, Bulletin of the American Mathematical Society, vol.54, issue.4, pp.431-438, 1948. ,
DOI : 10.1090/S0002-9904-1948-09022-X
An O(h2n) Hermite approximation for conic sections, Computer Aided Geometric Design, vol.14, issue.2, pp.135-151, 1997. ,
DOI : 10.1016/S0167-8396(96)00025-8
Quadratic approximation to plane parametric curves and its application in approximate implicitization, The Visual Computer, vol.36, issue.5, pp.906-917, 2006. ,
DOI : 10.1007/s00371-006-0075-6
Asymptotic approximation of convex curves, Archiv der Mathematik, vol.21, issue.4, pp.377-384, 1994. ,
DOI : 10.1007/BF01189576
Asymptotic approximation of convex curves; the Hausdorff metric case, Archiv der Mathematik, vol.70, issue.4, pp.331-336, 1998. ,
DOI : 10.1007/s000130050203
Asymptotic approximation by quadratic spline curves, Ann. Univ. Sci. Budapest, Sectio Math, vol.42, pp.133-139, 1999. ,
Polygonal approximation of plane convex bodies, Journal of Mathematical Analysis and Applications, vol.51, issue.2, pp.326-358, 1975. ,
DOI : 10.1016/0022-247X(75)90125-0
On a numerically efficient method for computing multivariate B-splines, Multivariate Approximation Theory, pp.211-248, 1979. ,
DOI : 10.1007/978-3-0348-6289-9_14
VorlesungenüberVorlesungen¨Vorlesungenüber Differenzenrechnung, volume XIII of Grundlehren der Mathematischen Wissenschaften, 1924. ,
Affine invariant detection: edge maps, anisotropic diffusion, and active contours, Acta Applicandae Mathematicae, vol.59, issue.1, pp.45-77, 1999. ,
DOI : 10.1023/A:1006295328209
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.10.1516
Projective Differential Geometry Old and New. From the Schwarzian Derivative to the Cohomology of Diffeomorphism Groups, Cambridge Tracts in Mathematics, vol.165, 2005. ,
DOI : 10.1017/cbo9780511543142
Locally controllable conic splines with curvature continuity, ACM Transactions on Graphics, vol.10, issue.4, pp.366-377, 1991. ,
DOI : 10.1145/116913.116916
Approximation Theory and Methods, 1981. ,
Planar curve interpolation by piecewise conics of arbitrary type, Constructive Approximation, vol.6, issue.4, pp.373-389, 1993. ,
DOI : 10.1007/BF01204647
Variations on the Tait-Kneser theorem, 2006. ,
Curve fitting and fairing using conic splines, Computer-Aided Design, vol.36, issue.5, pp.461-472, 2004. ,
DOI : 10.1016/S0010-4485(03)00119-2
