Helly-type Theorems for Line transversals to Disjoint Unit Balls (Extended abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
We prove Helly-type theorems for line transversals to disjoint unit balls in R^d. In particular, we show that a family of n >= 2d disjoint unit balls in Rd has a line transversal if, for some ordering of the balls, every subfamily of 2d balls admits a line transversal consistent with . We also prove that a family of n >= 4d − 1 disjoint unit balls in R^d admits a line transversal if every subfamily of size 4d − 1 admits a transversal.
extended-abstract.pdf (96.14 Ko) Télécharger le fichier
inria-00189019 , version 1 (12-11-2009)
  • HAL Id : inria-00189019 , version 1
Otfried Cheong, Xavier Goaoc, Andreas Holmsen, Sylvain Petitjean. Helly-type Theorems for Line transversals to Disjoint Unit Balls (Extended abstract). European Workshop on Computational Geometry, Mar 2006, Delphi, Greece. pp.87--89. ⟨inria-00189019⟩
173 Consultations
134 Téléchargements
