Voltage-stepping schemes for the simulation of spiking neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Neuroscience Année : 2009
The numerical simulation of spiking neural networks requires particular attention. On the one hand, time-stepping methods are generic but theyhardly reproduce accurately the short-time scale uctuations of spiking neurons and need specific treatments to avoid the errors associated with the dis-continuities of ntegrate-and-fire models. On the other hand, event-driven methods are exact but restricted to a limited class of models. We present here a oltage-stepping scheme that combines the advantages of these two approaches and consists of a discretization of the voltage state-space. The numerical simulation is reduced to a local event-driven method that induces an implicit activity-dependent time-stepping scheme: long time-steps are used when the neuron is slowly varying whereas small time-steps are used in periods of intense activity. Our method accurately approximates the neuronal dynamics and we show analytically that such a scheme leads to an high-order algorithm. We illustrate the voltage-stepping method on nonlinear integrate-and-fire models. In this situation, our method consists of an approximation of the original model by a voltage-dependent integrate-and-fire. We compare our method with time-stepping schemes of Runge-Kutta type.
JCNS.pdf (250.96 Ko) Télécharger le fichier
inria-00189386 , version 1 (20-11-2007)
inria-00189386 , version 2 (21-11-2007)
inria-00189386 , version 3 (21-11-2007)
inria-00189386 , version 4 (11-06-2009)
Gang Zheng, Arnaud Tonnelier, Dominique Martinez. Voltage-stepping schemes for the simulation of spiking neural networks. Journal of Computational Neuroscience, 2009, 26 (3), pp.409-423. ⟨10.1007/s10827-008-0119-1⟩. ⟨inria-00189386v4⟩
190 Consultations
411 Téléchargements
