A Knowledge-Intensive, Integrated Approach to Problem Solving and Sustained Learning. Doctoral dissertation, 1991. ,
Case-based Reasoning : Foundational Issues, Methodological Variations, and System Approaches. AI Communications, pp.39-59, 1994. ,
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
The Description Logic Handbook, 2003. ,
DOI : 10.1017/CBO9780511711787
Engineering and Learning of Adaptation Knowledge in Case-Based Reasoning, Proceedings of the 15th International Conference on Knowledge Engineering and Knowledge Management (EKAW-06), pp.303-317, 2006. ,
DOI : 10.1007/11891451_27
Introspective multistrategy learning: On the construction of learning strategies, Artificial Intelligence, vol.112, issue.1-2, pp.1-55, 1999. ,
DOI : 10.1016/S0004-3702(99)00047-8
Learning adaptation knowledge to improve case-based reasoning, Artificial Intelligence, vol.170, issue.16-17, pp.16-171175, 2006. ,
DOI : 10.1016/j.artint.2006.09.001
Case Base Mining for Adaptation Knowledge Acquisition, Proceedings of the 20th International Joint Conference on Artificial Intelligence (IJCAI'07), pp.750-755, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00127347
Adaptation Knowledge Acquisition : a Case Study for Case-Based Decision Support in Oncology, Computational Intelligence (an International Journal), vol.22, issue.34, pp.161-176, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00116888
Explaining and repairing plans that fail, Artificial Intelligence, vol.45, issue.1-2, pp.173-228, 1990. ,
DOI : 10.1016/0004-3702(90)90040-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.5827
Learning adaptation rules from a case-base, Advances in Case-Based Reasoning ? Third European Workshop, EWCBR'96, LNAI 1168, pp.179-192, 1996. ,
DOI : 10.1007/BFb0020610
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
DA2 merging operators, Artificial Intelligence, vol.157, issue.1-2, pp.49-79, 2004. ,
DOI : 10.1016/j.artint.2004.04.008
URL : http://doi.org/10.1016/j.artint.2004.04.008
Learning to Integrate Multiple Knowledge Sources for Case- Based Reasoning, Proceedings of the 15th International Joint Conference on Artificial Intelligence (IJCAI'97), pp.246-251, 1997. ,
A Definition and a Formalization of Conservative Adaptation for Knowledge-Intensive Case- Based Reasoning ? Application to Decision Support in Oncology (A Preliminary Report), 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00118757
Retrieval, reuse, revision and retention in case-based reasoning, The Knowledge Engineering Review, vol.20, issue.03, pp.215-240, 2005. ,
DOI : 10.1017/S0269888906000646
EPISTEMOLOGICAL PROBLEMS OF ARTIFICIAL INTELLIGENCE, Proceedings of the 5th International Joint Conference on Artificial Intelligence (IJCAI'77), Cambridge (Massachussetts), pp.1038-1044, 1977. ,
DOI : 10.1016/B978-0-934613-03-3.50035-0
The Knowledge Contained in Similarity Measures Invited Talk of the First International Conference on Case-Based Reasoning, ICCBR'95), 1995. ,
Inside Case-Based Reasoning, 1989. ,
Document Retrieval Systems ? Optimization and Evaluation, 1966. ,
Experiments on adaptation-guided retrieval in case-based design, Case-Based Reasoning Research and Development ? First International Conference, ICCBR'95, pp.313-324, 1010. ,
DOI : 10.1007/3-540-60598-3_28
Explanation in Case-Based Reasoning???Perspectives and Goals, Artificial Intelligence Review, vol.54, issue.1???2, pp.109-143, 2005. ,
DOI : 10.1007/s10462-005-4607-7
A Framework for Learning Adaptation Knowedge Based on Knowledge Light Approaches, Proceedings of the Fifth German Workshop on Case-Based Reasoning, pp.235-242, 1997. ,
