Case-based Reasoning : Foundational Issues, Methodological Variations, and System Approaches. AI Communications, pp.39-59, 1994. ,
Failure Analysis for Domain Knowledge Acquisition in a Knowledge-Intensive CBR System, Proceedings of the 7th international conference on case-based reasoning, 2007. ,
DOI : 10.1007/978-3-540-74141-1_32
Engineering and Learning of Adaptation Knowledge in Case-Based Reasoning, Proceedings of the 15th International Conference on Knowledge Engineering and Knowledge Management (EKAW-06), pp.303-317, 2006. ,
DOI : 10.1007/11891451_27
Learning adaptation knowledge to improve case-based reasoning, Artificial Intelligence, vol.170, issue.16-17, pp.16-171175, 2006. ,
DOI : 10.1016/j.artint.2006.09.001
Introspective Learning to Build Case-Based Reasoning (CBR) Knowledge Containers, Proceedings of the 3rd International Conference on Machine Learning and Data Mining in Pattern Recognition (MLDM 03), LNAI 2734, pp.1-6, 2003. ,
DOI : 10.1007/3-540-45065-3_1
Case Base Mining for Adaptation Knowledge Acquisition, Proceedings of the 20th International Joint Conference on Artificial Intelligence (IJCAI'07), pp.750-755, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00127347
Case Base Mining for Adaptation Knowledge Acquisition, Twentieth International Joint Conference on Artificial Intelligence -IJCAI'07, pp.750-755, 2007. ,
A general strategy for adaptation in case-based reasoning, 2006. ,
Explaining and repairing plans that fail, Artificial Intelligence, vol.45, issue.1-2, pp.173-228, 1990. ,
DOI : 10.1016/0004-3702(90)90040-7
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.103.5827
Learning adaptation rules from a case-base, Advances in Case-Based Reasoning ? Third European Workshop, EWCBR'96, LNAI 1168, pp.179-192, 1996. ,
DOI : 10.1007/BFb0020610
Learning to Integrate Multiple Knowledge Sources for Case- Based Reasoning, Proceedings of the 15th International Joint Conference on Artificial Intelligence (IJCAI'97), pp.246-251, 1997. ,
Une première formalisation de la phase d'élaboration du raisonnement à partir de cas, 14ème atelier francophone de raisonnement à partir de cas, 2006. ,
The Knowledge Contained in Similarity Measures Invited Talk of the First International Conference on Case-Based Reasoning, ICCBR'95), 1995. ,
Inside Case-Based Reasoning, 1989. ,
Retrieving adaptable cases, Topics in Case-Based Reasoning ? First European Workshop (EWCBR'93), pp.209-220, 1994. ,
DOI : 10.1007/3-540-58330-0_88
A Framework for Learning Adaptation Knowedge Based on Knowledge Light Approaches, Proceedings of the Fifth German Workshop on Case-Based Reasoning, pp.235-242, 1997. ,
