New interface
Journal articles
Generalization of the dual variational data assimilation algorithm to a nonlinear layered quasi-geostrophic ocean model
Didier Auroux 1
1 MOISE - Modelling, Observations, Identification for Environmental Sciences
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology
Abstract : In this paper, we present a generalization to nonlinear models of the fourdimensional variational dual method, the 4D-PSAS algorithm. The idea of 4D-PSAS (physical space analysis system) is to perform the minimization in the space of the observations, rather than in themodel space as in the primal 4DVAR scheme. Despite the formal equivalence between 4D-VAR and 4D-PSAS in a linear situation (both for model equations and observation operators), the dual method has several important advantages: in oceanographic cases, the observation space is smaller than the model space, which should improve theminimization process; for no additional cost, it provides an estimation of the model error; and finally, it does not have any singularities when the covariance errormatrices tend to zero. The idea of this paper is to extend this algorithm to a fully nonlinear situation, as has been done in previous years with other classical data assimilation schemes: the 4D-VARand theKalman filter. For this purpose, we consider a nonlinear multi-layer quasi-geostrophic ocean model, which mimics quite well the mid-latitude circulation.
Document type :
Journal articles
Complete list of metadata
Cited literature [46 references]  Display  Hide  Download
https://hal.inria.fr/inria-00189641
Contributor : Didier Auroux Connect in order to contact the contributor
Submitted on : Wednesday, November 21, 2007 - 3:42:38 PM
Last modification on : Thursday, January 20, 2022 - 5:28:09 PM
Long-term archiving on: : Monday, April 12, 2010 - 3:07:43 AM
File
auroux_rev_rev.pdf
Publisher files allowed on an open archive
Identifiers
Collections
Citation
Didier Auroux. Generalization of the dual variational data assimilation algorithm to a nonlinear layered quasi-geostrophic ocean model. Inverse Problems, 2007, 23, pp.2485-2503. ⟨10.1088/0266-5611/23/6/013⟩. ⟨inria-00189641⟩
Share
Metrics
Record views
110
Files downloads
160
