Solution approchée pour unprobì eme d'assimilation de données météorologiques avec prise en compte de l'erreur modèle, C.R. Acad. Sci. Paris, issue.II, pp.3211087-1094, 1995. ,
Data assimilation methods for an oceanographic problem ,
Inverse methods in physical oceanography, 1992. ,
DOI : 10.1017/CBO9780511600807
The Generalized Inverse of a Nonlinear Quasigeostrophic Ocean Circulation Model, Journal of Physical Oceanography, vol.22, issue.3, pp.213-230, 1992. ,
DOI : 10.1175/1520-0485(1992)022<0213:TGIOAN>2.0.CO;2
Generalized inversion of a global numerical weather prediction model, Meteorology and Atmospheric Physics, vol.7, issue.1-3, pp.165-178, 1996. ,
DOI : 10.1007/BF01029793
Generalized Inversion of Tropical Atmosphere???Ocean Data and a Coupled Model of the Tropical Pacific, Journal of Climate, vol.11, issue.7, pp.1768-1792, 1998. ,
DOI : 10.1175/1520-0442(1998)011<1768:GIOTAO>2.0.CO;2
Inverse Modeling of the Ocean and Atmosphere, 2002. ,
DOI : 10.1017/CBO9780511535895
Assimilation of TOPEX/POSEIDON altimeter data into a circulation model of the North Atlantic, Journal of Geophysical Research, vol.81, issue.C12, pp.24691-24705, 1994. ,
DOI : 10.1029/94JC01644
Assimilation of altimetric data in the mid-latitude oceans using the Singular Evolutive Extended Kalman filter with an eddy-resolving, primitive equation model, Journal of Marine Systems, vol.22, issue.4, pp.269-294, 1999. ,
DOI : 10.1016/S0924-7963(99)00044-5
A new double-rank minimization algorithm, Notices American Math. Soc, vol.16, p.670, 1969. ,
Mapping tropical Pacific sea level: Data assimilation via a reduced state space Kalman filter, Journal of Geophysical Research: Oceans, vol.46, issue.C10, pp.22599-22617, 1996. ,
DOI : 10.1029/96JC01684
Dual formulation of four-dimensional variational assimilation, Quarterly Journal of the Royal Meteorological Society, vol.121, issue.544, pp.2449-2461, 1997. ,
DOI : 10.1002/qj.49712354414
Using the extended Kalman filter with a multilayer quasi-geostrophic ocean model, Journal of Geophysical Research: Oceans, vol.93, issue.C2, pp.17905-17924, 1992. ,
DOI : 10.1029/92JC01972
Assimilation of Sea Surface Topography into an Ocean Circulation Model Using a Steady-State Smoother, Journal of Physical Oceanography, vol.23, issue.8, pp.1831-1855, 1993. ,
DOI : 10.1175/1520-0485(1993)023<1831:AOSSTI>2.0.CO;2
Assimilation of TOPEX sea level measurements with a reduced-gravity, shallow water model of the tropical Pacific Ocean, Journal of Geophysical Research, vol.115, issue.C12, pp.25027-25039, 1995. ,
DOI : 10.1029/95JC02083
Applied Optimal Estimation, 1974. ,
Meteorological data assimilation for oceanographers. Part I: Description and theoretical framework, Dynamics of Atmospheres and Oceans, vol.13, issue.3-4, pp.171-218, 1989. ,
DOI : 10.1016/0377-0265(89)90040-7
Data Assimilation in Meteorology and Oceanography, Adv. Geophys, vol.23, pp.141-265, 1991. ,
DOI : 10.1016/S0065-2687(08)60442-2
Some numerical experiments with variable-storage quasi-Newton algorithms, Mathematical Programming, vol.11, issue.2, pp.407-435, 1989. ,
DOI : 10.1007/BF01589113
Geosat sea-level assimilation in a tropical Atlantic model using Kalman filter, Ocean. Acta, vol.15, pp.567-574, 1992. ,
The Role of Mesoscale Eddies in the General Circulation of the Ocean???Numerical Experiments Using a Wind-Driven Quasi-Geostrophic Model, Journal of Physical Oceanography, vol.8, issue.3, pp.363-392, 1978. ,
DOI : 10.1175/1520-0485(1978)008<0363:TROMEI>2.0.CO;2
Atmospheric Modelling, Data Assimilation and Predictability, 2003. ,
Stochastic Processes and Filtering Theory. Academic, 1970. ,
Variational algorithms for analysis and assimilation of meteorogical observations: theoretical aspects, pp.97-110, 1986. ,
Sensitivity Analysis in Variational Data Assimilation, J. Meteo. Soc. Japan, issue.75, pp.1-245, 1997. ,
The use of adjoint equations to solve a variational adjustment problem with convective constraints, pp.309-322, 1985. ,
Contrôle optimal de systèmes gouvernés par deséquationsdeséquations aux dérivées partielles. Dunod, 1968. ,
On the limited memory BFGS method for large scale optimization, Mathematical Programming, vol.32, issue.2, pp.503-528, 1989. ,
DOI : 10.1007/BF01589116
Etude d'un algorithme d'assimilation variationnelle de donnéesdonnéesà contrainte faible. Mise en oeuvre sur le modèle océanique auxéquationsauxéquations primitives MICOM, 1999. ,
Implementation of a dual variational algorithm for assimilation of synthetic altimeter data in the oceanic primitive equation model MICOM, Journal of Geophysical Research: Oceans, vol.121, issue.1B, pp.9199-9212, 2001. ,
DOI : 10.1029/1999JC000060
A variational method for the resolution of a data assimilation problem in oceanography, Inverse Problems, vol.14, issue.4, pp.979-997, 1998. ,
DOI : 10.1088/0266-5611/14/4/014
Data Assimilation in a Quasi-geostrophic Open-Ocean Model of the Gulf Stream Region Using the Adjoint Method, Journal of Physical Oceanography, vol.21, issue.3, pp.398-427, 1991. ,
DOI : 10.1175/1520-0485(1991)021<0398:DAIAQG>2.0.CO;2
Application of the adjoint technique to processing of a standard section data set: World Ocean Circulation Experiment section S4 along 67??S in the Pacific Ocean, Journal of Geophysical Research, vol.16, issue.4586, pp.865-879, 1994. ,
DOI : 10.1029/94JC01910
Geophysical fluid dynamics, 1979. ,
A singular evolutive extended Kalman filter for data assimilation in oceanography, Journal of Marine Systems, vol.16, issue.3-4, pp.323-340, 1998. ,
DOI : 10.1016/S0924-7963(97)00109-7
Stochastic Methods for Sequential Data Assimilation in Strongly Nonlinear Systems, Monthly Weather Review, vol.129, issue.5, pp.1194-1207, 2001. ,
DOI : 10.1175/1520-0493(2001)129<1194:SMFSDA>2.0.CO;2
URL : https://hal.archives-ouvertes.fr/inria-00073082
The ECMWF operational implementation of four-dimensional variational assimilation. I: Experimental results with simplified physics, Quarterly Journal of the Royal Meteorological Society, vol.121, issue.564 ,
DOI : 10.1002/qj.49712656415
Variational Assimilation of Geosat Data into an Eddy-resolving Model of the Gulf Stream Extension Area, Journal of Physical Oceanography, vol.23, issue.5, pp.925-953, 1993. ,
DOI : 10.1175/1520-0485(1993)023<0925:VAOGDI>2.0.CO;2
Variational Assimilation of XBT Data. Part 1, Journal of Physical Oceanography, vol.20, issue.5, pp.672-688, 1990. ,
DOI : 10.1175/1520-0485(1990)020<0672:VAOXDP>2.0.CO;2
Variational Assimilation of Meteorological Observations With the Adjoint Vorticity Equation. I: Theory, Quarterly Journal of the Royal Meteorological Society, vol.8, issue.10, pp.1311-1328, 1987. ,
DOI : 10.1002/qj.49711347812
Assimilation of observations, an introduction, J. Met. Soc. Japan, issue.1B, pp.75191-209, 1997. ,
Fitting dynamics to data, Journal of Geophysical Research, vol.16, issue.C2, pp.1227-1240, 1988. ,
DOI : 10.1029/JC093iC02p01227
Time-space weak-constraint data assimilation for nonlinear models, Tellus A: Dynamic Meteorology and Oceanography, vol.124, issue.4, pp.412-421, 2000. ,
DOI : 10.3402/tellusa.v52i4.12277
Limited-memory BFGS diagonal preconditioners for a data assimilation problem in meteorology, Optimization and Engineering, vol.1, issue.3, pp.323-339, 2000. ,
DOI : 10.1023/A:1010030224033
Assimilation of Geosat data into a quasigeostrophic model of the North Atlantic between 20N and 50N: preliminary results, Oceanol. Acta, vol.15, issue.5, pp.575-583, 1992. ,
An extended Kalman filter to assimilate satellite altimeter data into a nonlinear numerical model of the tropical Pacific Ocean: Method and validation, Journal of Geophysical Research: Oceans, vol.93, issue.3-4, pp.5441-5458, 1999. ,
DOI : 10.1029/1998JC900079
