New interface
Conference papers
Faillure Analysis for Domain Knowledge Acquisition in a Knowledge-Intensive CBR System
Amélie Cordier 1 Béatrice Fuchs 2 Jean Lieber 3 Alain Mille 2
1 SILEX - Supporting Interaction and Learning by Experience
LIRIS - Laboratoire d'InfoRmatique en Image et Systèmes d'information
3 ORPAILLEUR - Knowledge representation, reasonning
INRIA Lorraine, LORIA - Laboratoire Lorrain de Recherche en Informatique et ses Applications
Abstract : A knowledge-intensive case-based reasoning system has profit of the domain knowledge, together with the case base. Therefore, acquiring new pieces of domain knowledge should improve the accuracy of such a system. This paper presents an approach for knowledge acquisition based on some failures of the system. The CBR system is assumed to produce solutions that are consistent with the domain knowledge but that may be inconsistent with the expert knowledge, and this inconsistency constitutes a failure. Thanks to an interactive analysis of this failure, some knowledge is acquired that contributes to fill the gap from the system knowledge to the expert knowledge. Another type of failures occurs when the solution produced by the system is only partial: some additional pieces of information are required to use it. Once again, an interaction with the expert involves the acquisition of new knowledge. This approach has been implemented in a prototype, called FrakaS, and tested in the application domain of breast cancer treatment decision support.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/inria-00189779
Contributor : Jean Lieber Connect in order to contact the contributor
Submitted on : Thursday, November 22, 2007 - 11:07:43 AM
Last modification on : Tuesday, October 25, 2022 - 4:19:16 PM
Long-term archiving on: : Monday, September 24, 2012 - 3:50:40 PM
File
cordier-fuchs-lieber-mille-ICC...
Identifiers
Citation
Amélie Cordier, Béatrice Fuchs, Jean Lieber, Alain Mille. Faillure Analysis for Domain Knowledge Acquisition in a Knowledge-Intensive CBR System. 7th International Conference on Case-Based Reasoning - ICCBR-07, D. Patterson, Aug 2007, Belfast, United Kingdom. pp.463--477, ⟨10.1007/978-3-540-74141-1_32⟩. ⟨inria-00189779⟩
Share
Metrics
Record views
322
Files downloads
189
