Interactive Knowledge Acquisition in Case Based Reasoning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In Case Based Reasoning (CBR), knowledge acquisition plays an important role as it allows to progressively improve the system's competencies. One of the approaches of knowledge acquisition consists in performing it while the system is used to solve a problem. An advantage of this strategy is that it is not to constraining for the expert: the system exploits its interactions to acquire pieces of knowledge it needs to solve the current problem and takes the opportunity to learn this new knowledge for future use. In this paper, we present two approaches of interactive knowledge acquisition in CBR. Both approaches rely on the exploitation of reasoning failures. Indeed, an interactive learning process aiming at correcting the solution and at learning new knowledge is triggered when a reasoning failure occurs.
cordier-fuchs-lieber-mille-WS-KDS-ICCBR07.pdf (155.13 Ko) Télécharger le fichier
inria-00189787 , version 1 (22-11-2007)
  • HAL Id : inria-00189787 , version 1
Amélie Cordier, Béatrice Fuchs, Jean Lieber, Alain Mille. Interactive Knowledge Acquisition in Case Based Reasoning. Workshop on Knowledge Discovery and Similarity, a workshop of the seventh International Conference on Case-Based Reasoning (ICCBR-07), D. C. Wilson and D. Khemani (volume editors), D. Wilson and D. Khemani, Aug 2007, Belfast, United Kingdom. ⟨inria-00189787⟩
309 Consultations
320 Téléchargements
