Negative Results on Idle Intervals and Periodicity for Multiprocessor Scheduling under EDF - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
In this paper we present negative results for global scheduling of implicit deadlines periodic systems under EDF. We reconsider the definition of the idle intervals from the uniprocessor case to the multiprocessor case. Unfortunately, this new definition does not provide feasibility results for these systems. We prove that the periodicity of an EDF-feasible schedule does not hold from the uniprocessor case to the multiprocessor case. A discussion for calculating this instant is provided.
Fichier non déposé
inria-00191165 , version 1 (25-11-2007)
  • HAL Id : inria-00191165 , version 1
Christelle Braun, Liliana Cucu. Negative Results on Idle Intervals and Periodicity for Multiprocessor Scheduling under EDF. Junior Researcher Workshop on Real-Time Computing - JRWRTC'07 in conjunction with the 15th International Conference on Real-Time and Network Systems - RTNS 2007, Apr 2007, Nancy, France. pp.23-26. ⟨inria-00191165⟩
81 Consultations
0 Téléchargements
