Deliverable D7.2 - Final report on benchmarking of management protocols
This deliverable summarizes key research results obtained during the second phase of the WP7 activities. The research activities addressed the performance evaluation of management frameworks (SNMP and JMX). For these management frameworks, the current work presents qualitative and quantitative requirements associated to the management task. The SNMP framework is analysed with respect to a set of traces gathered from an operational network. The JMX framework is analysed based on synthetic data obtained from a process injection driven activity.
