Atomic snapshots of shared memory, Journal of the ACM, vol.40, issue.4, pp.873-890, 1993. ,
DOI : 10.1145/153724.153741
Sharing memory robustly in message-passing systems, Journal of the ACM, vol.42, issue.1, pp.124-142, 1995. ,
DOI : 10.1145/200836.200869
Complexity of network synchronization, Journal of the ACM, vol.32, issue.4, pp.804-823, 1985. ,
DOI : 10.1145/4221.4227
Immediate atomic snapshots and fast renaming, Proceedings of the twelfth annual ACM symposium on Principles of distributed computing , PODC '93, pp.41-51, 1993. ,
DOI : 10.1145/164051.164056
-resilient asynchronous computations, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.91-100, 1993. ,
DOI : 10.1145/167088.167119
URL : https://hal.archives-ouvertes.fr/hal-00896459
A Simple Algorithmically Reasoned Characterization of Wait-free Computations, Proc. 16th ACM Symposium on Principles of Distributed Computing (PODC'97, pp.189-198, 1997. ,
The BG distributed simulation algorithm, Distributed Computing, vol.14, issue.3, pp.127-146, 2001. ,
DOI : 10.1007/PL00008933
A combinatorial characterization of the distributed 1-solvable tasks, Journal of Algorithms, vol.11, issue.3, pp.420-440, 1990. ,
DOI : 10.1016/0196-6774(90)90020-F
Unreliable failure detectors for reliable distributed systems, Journal of the ACM, vol.43, issue.2, pp.225-267, 1996. ,
DOI : 10.1145/226643.226647
The weakest failure detector for solving consensus, Journal of the ACM, vol.43, issue.4, pp.685-722, 1996. ,
DOI : 10.1145/234533.234549
More Choices Allow More Faults: Set Consensus Problems in Totally Asynchronous Systems, Information and Computation, vol.105, issue.1, pp.132-158, 1993. ,
DOI : 10.1006/inco.1993.1043
Weakening Failure Detectors for k-Set Agreement via the Partition Approach Proc, 21st Int'l Symposium on Distributed Computing (DISC'07), pp.123-138, 2007. ,
Consensus in the presence of partial synchrony, Journal of the ACM, vol.35, issue.2, pp.288-323, 1988. ,
DOI : 10.1145/42282.42283
Impossibility of distributed consensus with one faulty process, Journal of the ACM, vol.32, issue.2, pp.374-382, 1985. ,
DOI : 10.1145/3149.214121
Round-by-round Fault Detectors: Unifying Synchrony and Asynchrony, Proc. 17th ACM Symposium on Principles of Distributed Computing (PODC'00), pp.143-152, 1998. ,
DOI : 10.1145/277697.277724
Subconsensus Tasks: Renaming Is Weaker Than Set Agreement, Proc. 20th Int'l Symposium on Distributed Computing (DISC'06), pp.329-338, 2006. ,
DOI : 10.1007/11864219_23
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.93.4954
Gamma-accurate Failure Detectors, Proc. 1Oth Int'l Workshop on Distributed Algorithms (WDAG'96), pp.269-286, 1996. ,
DOI : 10.1007/3-540-61769-8_18
Wait-free synchronization, ACM Transactions on Programming Languages and Systems, vol.13, issue.1, pp.124-149, 1991. ,
DOI : 10.1145/114005.102808
Tight Bounds for k-Set Agreement with Limited Scope Accuracy Failure Detectors, Distributed Computing, pp.157-166, 2005. ,
Unifying synchronous and asynchronous message-passing models, Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.133-142, 1998. ,
DOI : 10.1145/277697.277722
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.41.448
The topological structure of asynchronous computability, Journal of the ACM, vol.46, issue.6, pp.858-923, 1999. ,
DOI : 10.1145/331524.331529
Timeliness, failure-detectors, and consensus performance, Proceedings of the twenty-fifth annual ACM symposium on Principles of distributed computing , PODC '06, pp.169-178, 2006. ,
DOI : 10.1145/1146381.1146408
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.142.401
Distributed Computing: Models and Methods. Handbook of Theoretical Computer Science, Volume B: Formal Models and Semantics, pp.1157-1199, 1990. ,
Distributed Algorithms, 1997. ,
A Layered Analysis of Consensus, SIAM Journal on Computing, vol.31, issue.4, pp.989-1021, 2002. ,
DOI : 10.1137/S0097539799364006
On the Computability Power and the Robustness of Set Agreementoriented Failure Detector Classes Extended abstract: Irreducibility and Additivity of Set Agreement-oriented Failure Detector Classes, Proc. PODC'06, pp.153-162, 2006. ,
Unreliable Failure Detectors with Limited Scope Accuracy and an Application to Consensus, Proc. 19th Int'l Conference on Foundations of Software Technology and Theoretical Computer Science (FST&TCS'99) Springer Verlag LNCS #1738, pp.329-340, 1999. ,
DOI : 10.1007/3-540-46691-6_26
Brief Announcement, Proc. 13th ACM Symposium on Principles of Distributed Computing (PODC'94, p.396, 1994. ,
Failure Detectors and the Wait-free Hierarchy, Proc. 14th ACM Symposium on Principles of Distributed Computing (PODC'95, pp.100-109, 1995. ,
Failure Detectors as Schedulers (An Algorithmically-Reasoned Characterization), 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00139317
-set agreement is impossible, Proceedings of the twenty-fifth annual ACM symposium on Theory of computing , STOC '93, pp.1449-1483, 2000. ,
DOI : 10.1145/167088.167122
URL : https://hal.archives-ouvertes.fr/hal-00192526
On Conspiracies and Hyperfairness in Distributed Computing, Proc. 19th Int'l Symposium on Distributed Computing (DISC'05), pp.33-47, 2005. ,
DOI : 10.1007/11561927_5
Structured derivations of consensus algorithms for failure detectors, Proceedings of the seventeenth annual ACM symposium on Principles of distributed computing , PODC '98, pp.297-308, 1998. ,
DOI : 10.1145/277697.277755
Anti-Omega: the weakest failure detector for set agreement, 2007. ,
