Multimedia Document Models, 2000. ,
Automatic temporal layout mechanisms revisited, ACM Transactions on Multimedia Computing, Communications, and Applications, 2005. ,
DOI : 10.1145/1047936.1047942
Authoring multimedia documents using WYSIWYM editing, Proceedings of the 18th conference on Computational linguistics -, 2000. ,
DOI : 10.3115/990820.990853
Constraint Technique for Authoring Multimedia, 2001. ,
Le temps dans les documents, 2004. ,
Comparative analysis of six XML schema languages, ACM SIGMOD Record, vol.29, issue.3, 2000. ,
DOI : 10.1145/362084.362140
LimSee3 Document Model v1.03, 2006. ,
Taxonomy of XML Schema Languages using Formal Language Theory. Extreme Markup Languages, 2000. ,
Multimedia authoring tools, Conference companion on Human factors in computing systems common ground, CHI '96, 1996. ,
DOI : 10.1145/257089.257384
Modélisation et traitement du contenu des médias pour l'édition et la présentation de documents multimédias, Thèse, 2003. ,
Simple Standards-Based Slide Show System (S5), 2006. ,
Synchronized Multimedia ,
