Estimation and Tracking: Principles , Techniques and Software, 1993. ,
DOI : 10.1109/map.1996.491294
Robot localization based on scan-matching???estimating the covariance matrix for the IDC algorithm, Robotics and Autonomous Systems, vol.44, issue.1, pp.29-40, 2003. ,
DOI : 10.1016/S0921-8890(03)00008-3
A method for registration of 3-D shapes, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.14, issue.2, pp.239-256, 1992. ,
DOI : 10.1109/34.121791
A Probabilistic Framework for Robust and Accurate Matching of Point Clouds, 26th Pattern Recognition Symposium (DAGM 04), 2004. ,
DOI : 10.1007/978-3-540-28649-3_59
The normal distributions transform: a new approach to laser scan matching, Proceedings 2003 IEEE/RSJ International Conference on Intelligent Robots and Systems (IROS 2003) (Cat. No.03CH37453), 2003. ,
DOI : 10.1109/IROS.2003.1249285
Random sample consensus: a paradigm for model fitting with applications to image analysis and automated cartography, Communications of the ACM, vol.24, issue.6, pp.381-395, 1981. ,
DOI : 10.1145/358669.358692
Optimization of the simultaneous localization and map-building algorithm for real-time implementation, IEEE Transactions on Robotics and Automation, vol.17, issue.3, 2001. ,
DOI : 10.1109/70.938382
The robotics data set repository (radish), 2007. ,
Introduction to Applied Statistics: A Modelling Approach, 2004. ,
Robot pose estimation in unknown environments by matching 2d range scans, CVPR94, pp.935-938, 1994. ,
Globally consistent range scan alignment for environment mapping, Autonomous Robots, vol.4, issue.4, pp.333-349, 1997. ,
DOI : 10.1023/A:1008854305733
Weighted line fitting algorithms for mobile robot map building and efficient data representation, 2003 IEEE International Conference on Robotics and Automation (Cat. No.03CH37422), pp.1304-1311, 2003. ,
DOI : 10.1109/ROBOT.2003.1241772
Simultaneous Localization, Mapping and Moving Object Tracking, The International Journal of Robotics Research, vol.26, issue.9, 2004. ,
DOI : 10.1177/0278364907081229
Online simultaneous localization and mapping with detection and tracking of moving objects: Theory and results from a ground vehicle in crowded urban areas, Proceedings of the IEEE International Conference on Robotics and Automation (ICRA), 2003. ,
An introduction to the Kalman filter, 2006. ,
Scan matching based on CLS relationships, IEEE International Conference on Robotics, Intelligent Systems and Signal Processing, 2003. Proceedings. 2003, pp.99-104, 2003. ,
DOI : 10.1109/RISSP.2003.1285556
