Design and Field Testing of an Autonomous Underground Tramming System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Joshua A. Marshall
  • Fonction : Auteur
  • PersonId : 845338
Timothy D. Barfoot
  • Fonction : Auteur
  • PersonId : 845339
This paper describes the design, implementation, and field testing of an infrastructureless system for autonomous tramming (or hauling) of a centerarticulated underground mining vehicle. Described is the development of a fast, reliable, and robust “autotramming” technology that does not require the installation of fixed infrastructure throughout the mine.
fsr_64.pdf (3.24 Mo) Télécharger le fichier
inria-00196656 , version 1 (13-12-2007)
  • HAL Id : inria-00196656 , version 1
Joshua A. Marshall, Timothy D. Barfoot. Design and Field Testing of an Autonomous Underground Tramming System. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00196656⟩
Collections
FSR2007
68 Consultations
222 Téléchargements
