On the equations of the moving curve ideal - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Algebra Année : 2009
Laurent Busé
Given a parametrization of a plane algebraic curve C, some explicit adjoint linear systems on C are described in terms of determinants. Moreover, some generators of the Rees algebra associated to this parametrization are presented. The main ingredient developed in this paper is a detailed study of the elimination ideal of two homogeneous polynomials in two homogeneous variables that form a regular sequence.
tfmbb.pdf (318.85 Ko) Télécharger le fichier
inria-00198350 , version 1 (17-12-2007)
inria-00198350 , version 2 (10-02-2009)
  • HAL Id : inria-00198350 , version 1
  • ARXIV : 0712.2671
Laurent Busé. On the equations of the moving curve ideal. Journal of Algebra, 2009. ⟨inria-00198350v1⟩
204 Consultations
244 Téléchargements
