Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, Epiciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Journal articles
Rational Invariants of a Group Action. Construction and Rewriting
Abstract : Geometric constructions applied to a rational action of an algebraic group lead to a new algorithm for computing rational invariants. A finite generating set of invariants appears as the coefficients of a reduced Gröbner basis. The algorithm comes in two variants. In the first construction the ideal of the graph of the action is considered. In the second one the ideal of a cross-section is added to the ideal of the graph. Zero-dimensionality of the resulting ideal brings a computational advantage. In both cases, reduction with respect to the computed Gröbner basis allows us to express any rational invariant in terms of the generators.
Complete list of metadata
https://hal.inria.fr/inria-00198847
Contributor : Evelyne Hubert Connect in order to contact the contributor
Submitted on : Tuesday, December 18, 2007 - 9:20:12 AM
Last modification on : Saturday, June 25, 2022 - 10:58:36 PM
Links full text
Identifiers
Collections
Citation
Evelyne Hubert, Irina Kogan. Rational Invariants of a Group Action. Construction and Rewriting. Journal of Symbolic Computation, Elsevier, 2007, Effective Methods in Algebraic Geometry (MEGA 2005), 42 (1-2), pp.203-217. ⟨10.1016/j.jsc.2006.03.005⟩. ⟨inria-00198847⟩
Share
Metrics
Record views
68
