Dealing with AADL End-to-end Flow Latency with UML MARTE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
AADL and MARTE are both modeling formalisms supporting the analysis of real-time embedded systems. We investigate how MARTE, with its Time Model facilities, can be made to represent faithfully AADL periodic/aperiodic tasks communicating through event or data ports, in an approach to end-to-end flow latency analysis.
RR-FlowLatency.pdf (585.09 Ko) Télécharger le fichier
inria-00200834 , version 1 (21-12-2007)
inria-00200834 , version 2 (04-01-2008)
inria-00200834 , version 3 (04-01-2008)
inria-00200834 , version 4 (25-03-2008)
inria-00200834 , version 5 (27-03-2008)
  • HAL Id : inria-00200834 , version 5
Su-Young Lee, Frédéric Mallet, Robert de Simone. Dealing with AADL End-to-end Flow Latency with UML MARTE. [Research Report] RR-6402, INRIA. 2008, pp.20. ⟨inria-00200834v5⟩
408 Consultations
655 Téléchargements
