Robust Feature Extraction and Matching for Omnidirectional Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
This paper presents a new and robust method for extracting and match- ing visual vertical features between images taken by an omnidirectional camera. Matching robustness is achieved by creating a descriptor which is unique and dis- tinctive for each feature. Furthermore, the proposed descriptor is invariant to ro- tation. The robustness of the approach is validated through real experiments with a wheeled robot equipped with an omnidirectional camera. We show that vertical lines are very well extracted and tracked during the robot motion. At the end, we also present an application of our algorithm to the robot simultaneous localization and mapping in an unknown environment.
fsr_71.pdf (361.3 Ko) Télécharger le fichier
inria-00200862 , version 1 (21-12-2007)
  • HAL Id : inria-00200862 , version 1
Davide Scaramuzza, Nicolas Criblez, Agostino Martinelli, Roland Siegwart. Robust Feature Extraction and Matching for Omnidirectional Images. 6th International Conference on Field and Service Robotics - FSR 2007, Jul 2007, Chamonix, France. ⟨inria-00200862⟩
119 Consultations
259 Téléchargements
