Differential Geometry of Curves and Surfaces, 1976. ,
High-level cad model acquisition from range images, Computer-Aided Design, vol.29, issue.4, pp.321-330, 1997. ,
DOI : 10.1016/S0010-4485(96)00059-0
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.52.8995
Geometric least-squares fitting of spheres, cylinders, cones and tori, 1997. ,
Natural quadrics in mechanical design, Autofact West, vol.1, pp.363-378, 1980. ,
Sparse low-degree implicit surfaces with applications to high quality rendering, feature extraction, and smoothing, SGP '05: Proceedings of the 2005 Eurographics/ACM SIGGRAPH symposium on Geometry processing: Eurographics Association, 2005. ,
Multi-level partition of unity implicits, ACM Transactions on Graphics, vol.22, issue.3, pp.463-470, 2003. ,
DOI : 10.1145/882262.882293
Segmentation of range images into planar surfaces by split and merge, CVPR '86: In Proc. of International Conference on Computer Vision and Pattern Recognition (CVPR '86), pp.415-417, 1986. ,
A survey of methods for recovering quadrics in triangle meshes, ACM Computing Surveys, vol.34, issue.2, pp.211-262, 2002. ,
DOI : 10.1145/508352.508354
URL : https://hal.archives-ouvertes.fr/inria-00100762
Solid Modeling: A Historical Summary and Contemporary Assessment, IEEE Computer Graphics and Applications, vol.2, issue.2, pp.9-22, 1982. ,
DOI : 10.1109/MCG.1982.1674149
Feature-based reverse engineering of mechanical parts, IEEE Transactions on Robotics and Automation, vol.15, issue.1, 1999. ,
DOI : 10.1109/70.744602
Extending the graphic pipeline with new gpu-accelerated primitives Also presented in Visgraf Seminar, 24th International gOcad Meeting, 2004. ,
Faithful recovering of quadric surfaces from 3D range data, Second International Conference on 3-D Digital Imaging and Modeling (Cat. No.PR00062), 1999. ,
DOI : 10.1109/IM.1999.805358
Structure recovery via hybrid variational surface approximation, Proceedings of Eurographics '04), pp.277-284, 2005. ,
