Atlas-Based Character Skinning with Automatic Mesh Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2008
Lin Lu
  • Fonction : Auteur
  • PersonId : 845872
Cédric Gérot
Boris Thibert
Skinning is the most tedious part in the character animation process. Using standard methods, joint weights must be attached to each vertex of the character's mesh, which is often time-consuming if an accurate animation is required. We propose a new modeling of the skinning process, inspired by the notion of atlas of charts. Starting from the character's animation skeleton, we first automatically decompose the mesh into anatomically meaningful overlapping regions. Regions are then blended in their overlapping parts using continuous transition functions. This leads to a simple yet efficient skinning process for which the weights are automatically defined and do not depend on the Euclidean distance but on the distance on the surface.
RR-6406.pdf (1.63 Mo) Télécharger le fichier
inria-00202597 , version 1 (07-01-2008)
inria-00202597 , version 2 (09-01-2008)
inria-00202597 , version 3 (14-01-2008)
inria-00202597 , version 4 (18-01-2010)
  • HAL Id : inria-00202597 , version 2
Lin Lu, Franck Hétroy, Cédric Gérot, Boris Thibert. Atlas-Based Character Skinning with Automatic Mesh Decomposition. [Research Report] RR-6406, 2008, pp.21. ⟨inria-00202597v2⟩
Collections
INRIA-RRRT
520 Consultations
701 Téléchargements
