Parallel color space converters for, JPEG image compression. Microelectronics Reliability, vol.44, issue.4, pp.697-703, 2004. ,
Multi-criteria Scheduling of Pipeline Workflows, HeteroPar'07, Algorithms, Models and Tools for Parallel Computing on Heterogeneous Networks (in conjunction with Cluster, 2007. ,
URL : https://hal.archives-ouvertes.fr/inria-00156732
Efficient collective communication in distributed heterogeneous systems, Journal of Parallel and Distributed Computing, vol.63, pp.251-263, 2003. ,
, The JPEG2000 still image coding system: an overview. IEEE Transactions on Consumer Electronics, vol.46, pp.1103-1127, 2000.
Parallel image compression with jpeg for multimedisa applications, High Performance Computing: Technologies, Methods and Applications, pp.379-394, 1995. ,
A Parallel Pipelined Implementation of LOCO-I for JPEG-LS, 17th International Conference on Pattern Recognition (ICPR'04), vol.1, pp.769-772, 2004. ,
, Acceleration of DCT Processing with Massive-Parallel Memory-Embedded SIMD Matrix Processor. IEICE Transactions on Information and Systems -LETTER-Image Processing and Video Processing, pp.1312-1315, 2007.
Parallel JPEG2000 Image Coding on Multiprocessors, IPDPS'02, International Parallel and Distributed Processing Symposium, 2002. ,
Efficient high-performance ASIC implementation of JPEG-LS encoder, Proceedings of the Conference on Design, Automation and Test in Europe (DATE2007), 2007. ,
Architectural Exploration of Heterogeneous Multiprocessor Systems for JPEG, International Journal of Parallel Programming, vol.35, 2007. ,
An overview of parallel processing approaches to image and video compression, Image and Video Compression, volume Proc. SPIE 2186, pp.197-208, 1994. ,
Optimal latency-throughput tradeoffs for data parallel pipelines, ACM Symposium on Parallel Algorithms and Architectures SPAA'96, pp.62-71, 1996. ,
The JPEG still picture compression standard, Commun. ACM, vol.34, issue.4, pp.30-44, 1991. ,
A Fast Computational Algorithm for the Discrete Cosine Tranfsorm, IEEE Transactions on Communications, vol.25, issue.9, pp.1004-1009, 1977. ,
, Parc Club Orsay Université -ZAC des Vignes 4, rue Jacques Monod -91893 ORSAY Cedex
LORIA, Technopôle de Nancy-Brabois -Campus scientifique 615, rue du Jardin Botanique -BP 101 -54602 ,
