Considérations sur le frottement de glissement, Nouv. Ann. de Math, vol.20, pp.485-496, 1920. ,
Some numerical methods in multibody dynamics : application to granular materials, European J. of Mechanics A/Solids, vol.13, issue.4, pp.93-114, 1994. ,
Nonsmooth Mechanics, 1999. ,
URL : https://hal.archives-ouvertes.fr/hal-01236953
Impact Mechanics, 2000. ,
DOI : 10.1017/CBO9780511626432
Non-Smooth Thermo-Mechanics, 2002. ,
On multiple impact, Journal of Applied Mathematics and Mechanics, vol.59, issue.6, pp.887-902, 1995. ,
DOI : 10.1016/0021-8928(95)00122-0
Multiple impacts with friction in rigid multibody systems, Nonlinear Dynamics, vol.7, pp.471-497, 1995. ,
Multibody Dynamics with Unilateral Contacts, Wiley Series in Nonlinear Science, 1996. ,
DOI : 10.1002/9783527618385
Rigid-Body Dynamics with Friction and Impact, SIAM Review, vol.42, issue.1, pp.3-39, 2000. ,
DOI : 10.1137/S0036144599360110
A New Look at an Old Problem: Newton???s Cradle, Journal of Applied Mechanics, vol.68, issue.4, pp.575-583, 2001. ,
DOI : 10.1115/1.1344902
Modeling the dependence of the coefficient of restitution on the impact velocity in elasto-plastic collisions, International Journal of Impact Engineering, vol.27, issue.3, pp.317-341, 2003. ,
DOI : 10.1016/S0734-743X(01)00052-5
Oblique elastic???plastic impact between rough cylinders in plane strain, International Journal of Engineering Science, vol.37, issue.1, pp.97-122, 1999. ,
DOI : 10.1016/S0020-7225(98)00026-3
The FEM analysis and approximate model for cylindrical joints with clearances, Mechanism and Machine Theory, pp.183-197, 2007. ,
DOI : 10.1016/j.mechmachtheory.2006.02.006
Numerical and experimental investigation of radial impacts on a half-circular plate, Multibody System Dynamics, vol.9, issue.3, pp.265-281, 2003. ,
DOI : 10.1023/A:1022991831100
Impact model resolution on Painlevé's paradox, Acta Mechanica Sinica, vol.20, issue.6, pp.649-660, 2004. ,
A Critical Study of the Applicability of Rigid-Body Collision Theory, Journal of Applied Mechanics, vol.63, issue.2, pp.307-316, 1996. ,
DOI : 10.1115/1.2788865
Spring-dashpot models for the dynamics of a radially rotating beam with impact, Journal of Sound and Vibration, vol.142, issue.3, pp.515-525, 1990. ,
DOI : 10.1016/0022-460X(90)90665-M
A continuous force model for the impact analysis of flexible multi-body systems, Mechanism and Machine Theory, pp.213-224, 1987. ,
Continuous contact force models for impact analysis in multibody systems, Nonlinear Dynamics, vol.5, pp.193-207, 1994. ,
Modeling Contact Forces and Energy Dissipation During Impact in Multibody Mechanical Systems, 1997. ,
Modeling of joints with clearance in flexible multibody systems, International Journal of Solids and Structures, vol.39, issue.1, pp.41-63, 2002. ,
DOI : 10.1016/S0020-7683(01)00186-X
Analysis of rigid-body dynamic models for simulation of systems with frictional contacts, Journal of Applied Mechanics, vol.68, pp.118-128, 2001. ,
Concurrent multiple impacts modelling, Proc. of the MIT Conference on Computational Fluid and Solid Mechanics, pp.1836-1841, 2003. ,
DOI : 10.1016/B978-008044046-0.50450-4
URL : https://hal.archives-ouvertes.fr/inria-00424298
Toward a mutiple impact law: the 3-ball chain example " . Actes dusixì eme colloque National de Calculs des Structures, pp.337-344, 2003. ,
Concurrent Multiple impacts in rigid bodies. Formulation and simulation, ENOC 2005, pp.7-12, 2005. ,
URL : https://hal.archives-ouvertes.fr/inria-00424055
The theoretical analysis of three balls systems with multiple impacts, Chinese Journal of Theoretical and Applied Mechanics, vol.38, issue.5, pp.674-681, 2006. ,
Multi-Body Impact Motion with Friction???Analysis, Simulation, and Experimental Validation, Journal of Mechanical Design, vol.115, issue.3, pp.412-422, 1993. ,
DOI : 10.1115/1.2919206
Swerve During Three-Dimensional Impact of Rough Rigid Bodies, Journal of Applied Mechanics, vol.61, issue.3, pp.605-611, 1994. ,
DOI : 10.1115/1.2901502
Concepts for modeling impacts without friction, Acta Mechanica, vol.168, pp.1-19, 2004. ,
Two Interpretations of Rigidity in Rigid-Body Collisions, Journal of Applied Mechanics, vol.65, issue.4, pp.894-900, 1997. ,
DOI : 10.1115/1.2791929
Predicting Rebounds Using Rigid-Body Dynamics, Journal of Applied Mechanics, vol.58, issue.3, pp.754-758, 1991. ,
DOI : 10.1115/1.2897260
Numerical and experimental evaluation of the coefficient of restitution for repeated impacts, International Journal of Impact Engineering, vol.32, issue.1-4, pp.508-524, 2005. ,
DOI : 10.1016/j.ijimpeng.2005.01.001
On the use of the restitution condition in flexible body dynamics, Nonlinear Dynamics, vol.30, issue.1, pp.71-86, 2002. ,
DOI : 10.1023/A:1020337204996
The problem of constrained impact, Journal of Applied Mathematics and Mechanics, vol.61, issue.3, pp.341-353, 1997. ,
DOI : 10.1016/S0021-8928(97)00044-0
Etude geometrique sur les percussions et le choc des corps, Bulletin des Sciences Mathématiques et Astronomiques,deuxì eme série, pp.126-160, 1880. ,
DOI : 10.20537/nd1002013
Impact With Friction, Journal of Applied Mechanics, vol.53, issue.1, pp.1-4, 1986. ,
DOI : 10.1115/1.3171712
Impact Coefficients and Tangential Impacts, Journal of Applied Mechanics, vol.64, issue.4, pp.1014-1016, 1997. ,
DOI : 10.1115/1.2788967
The Sliding Velocity Flow of Rough Collisions in Multibody Systems, Journal of Applied Mechanics, vol.63, issue.3, pp.804-809, 1996. ,
DOI : 10.1115/1.2823366
The Jamb (Self-Locking) Process in Three-Dimensional Collisions, Journal of Applied Mechanics, vol.65, issue.2, pp.417-423, 1998. ,
DOI : 10.1115/1.2789070
Collision of a 1-D column of beads with a wall, The European Physical Journal B, vol.5, issue.1, pp.111-131, 1998. ,
DOI : 10.1007/s100510050424
Theoretical model for the pulse dynamics in a long granular chain, Physical Review E, vol.74, issue.4, pp.74-046602, 2006. ,
DOI : 10.1103/PhysRevE.74.046602
The bouncing motion appearing in a robotic system with unilateral constraint, Nonlinear Dynamics, vol.49, issue.1-2, pp.217-232, 2007. ,
DOI : 10.1007/s11071-006-9123-z
The fragmentation of a line of balls by an impact, Proceedings of the Royal Society, pp.3201-3220, 1999. ,
DOI : 10.1098/rspa.1999.0447
URL : https://hal.archives-ouvertes.fr/hal-00910111
Tunability of solitary wave property in one-dimensional strongly nonlinear phonic crystals, Phys. Rev. E, vol.73, 2006. ,
How Hertzian Solitary Waves Interact with Boundaries in a 1D Granular Medium, Physical Review Letters, vol.94, issue.17, p.178002, 2005. ,
DOI : 10.1103/PhysRevLett.94.178002
URL : https://hal.archives-ouvertes.fr/hal-00624695
Energetic coefficient of restitution for planar impact in multi-rigid-body systems with friction, International Journal of Impact Engineering, vol.31, issue.3, pp.255-265, 2005. ,
DOI : 10.1016/j.ijimpeng.2003.12.007
Levinson Dynamics: Theory and Applications, 1985. ,
On the Limitations of Predictions of the Dynamic Response of Machines with Clearance Connections, Journal of Mechanical Design, vol.116, issue.3, pp.833-841, 1994. ,
DOI : 10.1115/1.2919457
Rocking Newton???s cradle, American Journal of Physics, vol.72, issue.12, pp.1508-1516, 2004. ,
DOI : 10.1119/1.1783898
Anomalous behavior of normal kinematic restitution in the oblique impacts of a hard sphere on an elastoplastic plate, Physical Review E, vol.65, issue.2, p.21303 ,
DOI : 10.1103/PhysRevE.65.021303
Unilateral problems of dynamics, Archive of Applied Mechanics (Ingenieur Archiv), vol.69, issue.8, pp.503-527, 1999. ,
DOI : 10.1007/s004190050240
URL : https://hal.archives-ouvertes.fr/hal-01395964
Experimental treatment of multiplecontact-collisions, ENOC-2005 Proceedings, pp.450-459, 2005. ,
Stability properties of equilibrium sets of non-linear mechanical systems with dry friction and impact, Nonlinear Dynamics, vol.43, issue.4, 2008. ,
DOI : 10.1007/s11071-007-9244-z
Solving Ordinary Differential Equations II. Stiff and Differential-Algebraic Problems, Series in Computational Mathematics 14, 1996. ,
Solitary waves in a chain of beads under Hertz contact, Physical Review E, vol.56, issue.5, pp.6104-6117, 1997. ,
DOI : 10.1103/PhysRevE.56.6104
URL : https://hal.archives-ouvertes.fr/hal-01406853
Simulations of vibrated granular medium with impact-velocity-dependent restitution coefficient, Physical Review E, vol.71, issue.3, p.31302, 2005. ,
DOI : 10.1103/PhysRevE.71.031302
URL : https://hal.archives-ouvertes.fr/hal-00004178
Anomalous energy dissipation in molecular-dynamics simulations of grains: The ??????detachment?????? effect, Physical Review E, vol.50, issue.5, p.4113, 1994. ,
DOI : 10.1103/PhysRevE.50.4113
Numerical Dynamics of Granular Materials, Contact Mechanics J, pp.1-16, 2002. ,
DOI : 10.1007/978-94-017-1154-8_1
Solitary wave trains in granular chains: experiments, theory and simulations, Granular Matter, vol.59, issue.1, pp.13-20, 2007. ,
DOI : 10.1007/s10035-007-0054-2
URL : https://hal.archives-ouvertes.fr/hal-00624713
Strongly nonlinear wave dynamics in a chain of polymer coated beads, Physical Review E, vol.73, issue.2, p.26612, 2006. ,
DOI : 10.1103/PhysRevE.73.026612
CONTINUOUS DEPENDENCE ON DATA FOR VIBRO-IMPACT PROBLEMS, Mathematical Models and Methods in Applied Sciences, vol.15, issue.01, pp.53-93, 2005. ,
DOI : 10.1142/S0218202505003903
Contact law effects on wave propagation in particulate materials using distinct element modeling, International Journal of Non-Linear Mechanics, vol.28, issue.2, pp.251-265, 1993. ,
DOI : 10.1016/0020-7462(93)90061-O
