Abstract : In this paper we are concerned with modeling single phase flow in a medium with known fractures. In particular we are interested in the case in which the flow rate in the fractures is large enough to make it appropriate to use Forchheimer's law for modeling the flow in the fractures even though the flow in the surrounding domain is such that Darcy's law is adequate. We describe a model in which the fractures are treated as interfaces. We also consider the case of intersecting fractures and the case of nonconforming meshes.
https://hal.inria.fr/inria-00207993
Contributor : Rapport de Recherche Inria <>
Submitted on : Monday, January 21, 2008 - 9:02:29 AM Last modification on : Wednesday, October 28, 2020 - 12:10:04 PM Long-term archiving on: : Tuesday, September 21, 2010 - 3:13:09 PM
Najla Frih, Jean Roberts, Ali Saada. Modeling fractures as interfaces: a model for Forchheimer fractures. [Research Report] RR-6419, INRIA. 2008, pp.26. ⟨inria-00207993v2⟩
