Design and Implementation of Open-MX: High-Performance Message Passing over generic Ethernet hardware - Archive ouverte HAL Access content directly
Conference Papers Year : 2008
Open-MX is a new message passing layer implemented on top of the generic Ethernet stack of the Linux kernel. It provides high-performance communication on top of any Ethernet hardware while exhibiting the Myrinet Express application interface. Open-MX also enables wire-interoperability with Myricom's MXoE hosts. This article presents the design of the Open-MX stack which reproduces the MX firmware in a Linux driver. MPICH-MX and PVFS2 layers are already able to work flawlessly on Open-MX. The first performance evaluation shows interesting latency and bandwidth results on 1 and 10~gigabit hardware.
CAC-383-paper-1.pdf (164.54 Ko) Télécharger le fichier
Dates and versions
inria-00210704 , version 1 (21-04-2008)
Identifiers
Cite
Brice Goglin. Design and Implementation of Open-MX: High-Performance Message Passing over generic Ethernet hardware. Workshop on Communication Architecture for Clusters, held in conjunction with IPDPS 2008, Apr 2008, Miami, United States. ⟨10.1109/IPDPS.2008.4536140⟩. ⟨inria-00210704⟩
199 View
244 Download
Share
