Separation Logic Contracts for a Java-like Language with Fork/Join - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2008
Christian Haack
  • Fonction : Auteur
  • PersonId : 846315
We adapt a variant of permission-accounting separation logic to a concurrent Java-like language with fork/join. To support both concurrent reads and information hiding, we combine fractional permissions with abstract predicates. We present a separation logic contract for iterators that prevents data races and concurrent modifications. Our program logic is presented in an algorithmic style, based on a proof-theoretical logical consequence. We show that verified programs satisfy the following properties: data race freedom, absence of null-dereferences and partial correctness.
RR-6430.pdf (921.15 Ko) Télécharger le fichier
inria-00218114 , version 1 (25-01-2008)
inria-00218114 , version 2 (28-01-2008)
inria-00218114 , version 3 (27-02-2008)
inria-00218114 , version 4 (27-02-2008)
  • HAL Id : inria-00218114 , version 2
Christian Haack, Clément Hurlin. Separation Logic Contracts for a Java-like Language with Fork/Join. [Technical Report] RR-6430, 2008, pp.101. ⟨inria-00218114v2⟩
Collections
INRIA-RRRT
84 Consultations
360 Téléchargements
